Low buck tips to improve handling on the 77-96 D Body cars? - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 35 of 35
Like Tree1Likes
1985-1996 Fleetwood and Brougham Forum Discussion, Low buck tips to improve handling on the 77-96 D Body cars? in Past Cadillac Vehicle Discussion; I was just looking for the caprice 9c1 bushings but would definitely try the ones you got. Would you be ...
  1. #31
    Fleetwood472 is offline Cadillac Owners Fanatic
    Automobile(s): 78 Fleetwood w/ FI 472/ Switch pitch TH400
    Aug 2005
    240
    Re: Low buck tips to improve handling on the 77-96 D Body cars?
    I was just looking for the caprice 9c1 bushings but would definitely try the ones you got. Would you be able to send me a link to the thread or the p/n's of the body mounts? How does your car ride with the caprice body mounts?
  2. #32
    ferrisworld is offline Cadillac Owners Fanatic
    Automobile(s): 1979 Sedan Deville
    Feb 2005
    Sacramento, CA
    444
    I only did my lowers. Should probably do the uppers at some point. It definitely made the car feel more solid.
    http://www.impalassforum.com/vBullet...d.php?t=228472
    If you go to that link, at the bottom they talk about the "Scott Mueller Mod" and I'm pretty sure that's what I did.
    What do we do about the bushings on the front clip?
  3. #33
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Is the 9c1 front sway bar an improvement over the stock caddy sway bar? I'm going junkyarding tomorrow and will be taking some 9c1 springs home (definitely rear and maybe fronts) and was wondering if I should take the front sway bar as well? (I would take the rear sway bar too, but IIRC, a 90 tow package/350 brougham bar is the same as a 9c1 bar.
  5. #34
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,614
    I think they are the same.
  6. #35
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,933
    Easiest/quickest way to check/compare bar diameters is to use an open end wrench.
  7. Remove Advertisements
