cadillac
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Cadillac Technical Archive | Cadillac Dealers | Cadillac Reviews | Cadillac Dealer Reviews | Cadillac Vendors | Decals
gm social network
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
1985-1996 Fleetwood and Brougham Forum Discussion, 1993 Fleetwood hot start problem in Past Cadillac Vehicle Discussion; My 1993 Fleetwood Brougham starts fine when the engine is cold but after being driven in weather with temperatures above ...
    John D. Hague is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2007
    13
    My 1993 Fleetwood Brougham starts fine when the engine is cold but after being driven in weather with temperatures above 80 degrees and parked for about 20 minutes, the car will start, then sputter and die and then crank and crank before it will restart. When it restarts, it will splutter for about 5 - 10 seconds, then run fine. During cool weather, It doesn't have a problem.
    If the car sits for about an hour, it will start fine. I have replaced the fuel pump, the fuel pump relay, the oil pressure relay with no effect. The car sets no codes when this happens.
    Could this be a vapor lock or a fuel pressure regulator problem? Isn't the fuel pressure regulator hard to change on this car because it is built into the throttle body assembly?
    One clue is, if I force a fuel pump run when the car is hot, the car starts fine. I do that by applying 12 volts to the fuel pump test connector.
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Many
    96Fleetwood's Avatar
    96Fleetwood is offline Auto Enthusiast
    Automobile(s): Searching for the right one..
    Jul 2005
    Naperville, IL
    32
    3,579
    Re: 1993 Fleetwood hot start problem
    How about the EGR valve?
    1996 Cadillac Fleetwood Brougham "SS"- sold but not forgotten
    2010 BMW X5 3.0 Sport X-drive-wifes daily driver
    2002 Trans AM WS6 CE Convertible- the fun / show car 1 of 492
    2005 GMC Yukon Denali- slightly modded daily driver
    Oct 2007
    13
    The EGR Valve was also replaced without any effect on this problem.
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads)
    delzy's Avatar
    delzy is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Dev, 94 FW (crushed), 96 FW Limo (sold), 95 SLS (sold)
    Feb 2005
    The Last, Best Place
    368
    It sounds like you are boiling fuel in the line somewhere. Perhaps the fuel line or exhaust has been routed poorly?
    Oct 2007
    13
    I agree that it sounds like I am boiling fuel somehow. I have followed the fuel lines from the tank to the throttle body and it isn't obvious to me that they are routed near anything that should heat them up. Is there a likely spot for this to happen?
    I have even considered trying to insulate them some way but I don't know exactly how I would do that.
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,743
    Quote Originally Posted by John D. Hague View Post
    Put several old clothes pins along the fuel line. They will dissipate the heat.
    Oct 2007
    13
    I have just ordered 6 magnesium clip-type clothespins to attach to the fuel line to see if they would serve as a heat sink to keep the fuel line temperature below the boiling point of the fuel after the engine is shut off. Does that sound reasonable to anyone else?
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    45
    7,477
    Check the evaporative emissions too.
    Try removing the gas cap before you start and see if that fixes the problem. If there a misrouted or broken line in the evaporative emissions can cause strange issues.
    Check fuel pressure when you know the condition will happen. I would have checked fuel pressure first before throwing the pump and relay into it. You can toss a lot of money away throwing parts at a problem. Almost everything is troubleshootable, don't guess. Make sure if you take it to a mechanic that they don't do the same thing (all too many do the same blowing hundreds if not thousands of your money just troubleshooting because they don't have a clue). Find a GOOD mech that you can trust if you are taking it to one. Dealers aren't perfect either.
    Oct 2007
    13
    That sounds like excellent advice. So far, all of the fuel pressure readings have been well within spec.
    I'll check out the evaporative system tomorrow.
    Regarding the dealers, our Cadillac Dealer had the car for a week and the service manager drove the car home every night and they couldn't figure it out.
    I am determined to get this fixed. The car is pristine and a great car to drive with this one exception.
    Thanks for your guidance . . . .
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    45
    7,477
    Where are you located?
    GM had some issues with the B/D Bodies and getting one of the evaporative emissions hoses pinched from the factory. Take a look at the canister and all hoses in/out of it. You will probably have to climb under the car to see the canister in the front pass side.
    Oct 2007
    13
    Thanks for the advice.
    I am located in Indianapolis, Indiana.
    I just looked at the cannister, which is located on the left front side, and all of the hoses that I can see look fine. The electrical connections look solid and clean.
    I'll check the evap tubes under the car as soon as I can get the car on a lift where I can really take a close look at them.
    I just installed 6 magnesium clip-type clothes-pins along the fuel line on top of the engine, hoping that they might serve as a better heat sink for the fuel line. However, the temperature in Indianapolis today is 45 degrees so I can't duplicate the failure mode. The temperature needs to be in the 80s or so and then, after a 30 minute or more drive and a 20 to 30 minute park, the car will start immediately, then die. It will then crank for about 5 seconds and start again, flutter for about 5 seconds, and then run fine.
    I could live with that situation if I had to, if I believed that it would not worsen when I was on a trip and get me stranded. On that basis, the situation is very frustrating. I have this beautiful car that I am afraid to drive on any extended trip in warm weather.
    I deeply appreciate your advice.
    John
    Oct 2007
    13
    I just checked the evaporative system per the Factory Manual. The only problem that I discovered is a 30 ohm resistance to ground in the ECM connection that is supposed to supply a ground to the solenoid on the top of the cannister.
    I have a good 12 volt signal on one end of that solenoid but when the solenoid is loaded onto the circuit, the voltage across the solenoid is too low to pull in the solenoid. This is due to the 30 ohm reistance in the ground circuit.
    Is this likely to cause my hot start problem? If so, do I need a replacement ECM? Or, is this likely to be a connector problem in that ground line?
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    45
    7,477
    There should be a common ground point for the PCM, to the engine to the body, etc. I would look for them, they cause all sorts of headaches.
    Try to disconnect the vapor canister purge line from the throttle body to the engine. See if that fixes the hot start problem....
    Check the grounds all over, look for good engine to batt, batt to body, PCM to batt, etc. Make sure nothing is rusty or corroded over the years.
  16. #14
    Oct 2007
    13
    I just checked the grounds and, especially the ground for the ECM and all seem fine.
    I am now planning to take the car to the Cadillac dealer and ask them to duplicate my tests on the purge valve circuit and then change out the ECM if that is the problem.
    Do you believe that this purge solenoid problem could contribute to my hot start problem or is this just another problem?
    John
  17. #15
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    45
    7,477
    I would disconnect the line first, eliminate the purge canister from the equation.
    Do you have a leaking fuel pressure regulator? How long does it hold pressure after you shut the car off? It should for quite a while. If raw fuel is leaking in the TB, could be a problem.
    Question. In the hot start mode will it start on carb cleaner spray?? DO NOT spray the electrical part of the injectors. this could spark a fire. Have someone crank it and have you handy to spray down below the injectors.
Sponsored Cadillac Ads - Click here to show your support and REMOVE advertisements!
  • You may not post replies
Read about Cadillac ATS | Cadillac ATS Forum | Lincoln | Buick | Hyundai Genesis Forum | Kia Forte Forum
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | Cadillac Chrome and Black Chrome Wheels | window tinting
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
