1990 Vacuum schematic
Results 1 to 11 of 11
1985-1996 Fleetwood and Brougham Forum Discussion, 1990 Vacuum schematic in Past Cadillac Vehicle Discussion; Hey everyone, I was wondering if there is anyone that has a vacuum schematic for 1990 Fleetwood Brougham(5.0), If so ...
    aidan2474 is offline Cadillac Owners Member
    Apr 2004
    3
    Hey everyone,
    I was wondering if there is anyone that has a vacuum schematic for 1990 Fleetwood Brougham(5.0), If so please let me know because my Cadillac is running like a fresh turd . If not any other help would be greatly appreciated.
    Tony
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    Re: 1990 Vacuum schematic
    It's not on the emissions label under the hood?
    Pjs's Avatar
    Pjs
    Pjs is offline Cadillac Owners Fanatic
    Mar 2004
    Nashville, TN
    367
    Here's the link to AllData's vacuum diagram for the 91' 5.0
    http://www.alldatadiy.com/alldata/AF...71487/42028518
    Pjs's Avatar
    Pjs
    Mar 2004
    Nashville, TN
    367
    FYI,
    For the past year, I've been beating my head against a wall trying to figure out a problem that didn't much make sense to me, I did however solve the problem and am going to share in case someone else has had the same situation.
    Although my engine has 180K on it, it's in real good shape, great compression, doesn't burn any oil and idles so smooth you can hardly tell the engine is running. The problem though has been that I've got so much blow by coming through the breather filter in the air cleaner that it loads the air filter housing w/ oil, not to mention that it literally melts the filter. Of course my first thought is that the PCV valve is not functioning. The valve was fine, and there seemed to be plenty of vacuum, but thinking maybe I've replaced it w/ the wrong one prompted me to buy a couple of them.
    Still have the problem...one year later
    Last week I went through my usual 3 month ritual, replace the air filter, breather filter and clean the PCV. As the engine was running I pulled the PCV, lo and behold...no vacuum. I pulled the hose off the bottom of the TBI and was surprised to see the hose nipple completely clogged w/ carbon build-up. Not only was the TBI clogged, but the hose itself was clogged as well. After a can of B-12 the PCV system seems to be working fine and no blow by to speak of. Apparently, although there was vacuum on the PCV, it wasn't enough.
    Patrick
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,465
    Quote Originally Posted by Pjs
    That link says you need to log in.
    The 1990 engine is different then the 1991. El Dobro's right that it should be on a sticker under the hood.
    Apr 2004
    3
    thanks for the replies,
    but to answer your question,... the schematic on the car is unreadable
    and yes that alldata site has a login, if you want to PM me with your username and password that would be great !!!!!!!
    So if there is anyone else that can help me , please respond
    Apr 2004
    3
    Bump !
    Whytie is offline Cadillac Owners Member
    Jul 2004
    1
    I've got the same problem with blow-by. What is B-12??
    Jonnylightning71 is offline Cadillac Owners Member
    Automobile(s): 1990 Caddilac Brougham Fleetwood
    Jan 2013
    25
    9
    LOL I am with you brother. I own a 1998 eclipse and a 1970 dodge charger. Caddilacs IMO the worst supported car ever you cant find a god damn thing for these cars when it comes to schematics it really erates the hell out of me.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,614
    Whoa, 9 years has got to be the farthest I've seen someone dig. The info is hard to find...outside this forum. I have a 90 service manual and Sven has a nice little diagram he made that makes things easy.
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Just for reference, and anyone else looking information in this very dead thread:
    This is the vacuum diagram for the Oldsmobile 307 (5.0 V8), used in Cadillac Rear Wheel Drive models form 1986 to 1990
  14. Remove Advertisements
