Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > RWD 19xx-1984 DeVille and Fleetwood,
1985-1996 Fleetwood and Brougham Forum
Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille
and Fleetwood, 1985-1996 Fleetwood/Brougham.
Cadillac Forums: 1975 fleetwood towing capacity Help me out fleet!!
  #16 (permalink)
Old 09-21-07, 12:25 AM
Cadillac(s): 1975 Cadillac Fleetwood 75
View lesinfamous's Photo Album
Casino Cash: $7780
Re: 1975 fleetwood towing capacity Help me out fleet!!
o yea annd thanksss alot for posting it on fullsizechevys...im looking at it now actually!!!
  #17 (permalink)
Old 09-21-07, 02:51 AM
Casino Cash: $7780
as a matter of fact.....how is this????
  #18 (permalink)
Old 09-21-07, 09:24 AM
N0DIH's Avatar
Cadillac Owners Master
Cadillac(s): 94 Fleetwood Brougham
View N0DIH's Photo Album
Casino Cash: $9147
Looks like a photoshop reverse of the other....
  #19 (permalink)
Old 09-21-07, 10:38 AM
The Ape Man's Avatar
Cadillac(s): '80 CDV, '80 Fleetwood Coupe, 1994 Mercedes 140 Coupe
View The Ape Man's Photo Album
Casino Cash: $250
If your radiator is old and tired then the 4 row can't hurt. If your radiator is in good condition don't bother. An add on transmission cooler would probably be a better way to lose extra towing heat.
It's not a good idea to exceed vehicle weight when towing. Yours is in the 5000 lb range depending. Might be as high as 5800. This is not GVWR which is the listed vehicle weight PLUS load carrying capacity.
Towing high weights can lead to dangerous control problems. Trailer tongue weight should always be a certain percentage of total trailer weight. After a certain weight the car will exhibit a saggy back end. I'd add aftermarket air shocks to the car. The factory load leveling system limits trailer tongue weight by allowing the back of the car to sag as it only lifts a few hundred pounds. Aftermarket air shocks provide much more lifting capability. Been there.
Make sure things like the distributor vacuum and mechanical advance are working properly and the car is tuned up. The radiator fan clutch is very important and should be free of debris around the thermostatic spring. Core (freeze-out) plugs can sometimes be rotten on old engines. You might want to get a good look at yours. They can really ruin your day if one pops out on the road. The 500 engine will have no problem pulling a house if it is in good condition. The limits are road manners of the whole system.
  #20 (permalink)
Old 09-21-07, 01:06 PM
Casino Cash: $250
BTW, the WIKI Cadillac information concerning rear axles from '71 to '76 is incorrect.
  #21 (permalink)
Old 09-21-07, 02:00 PM
N0DIH's Avatar
Casino Cash: $9147
Ape speaks wisdom on towing....
  #22 (permalink)
Old 09-21-07, 09:18 PM
Casino Cash: $7780
this is off of a 72 fleetwood ....any resemblence ???
  #23 (permalink)
Old 09-21-07, 09:52 PM
Casino Cash: $250
There ain't a lot of information about these on the WWW. They were very trouble free. I've worked on a lot of Cadillacs but have not had occasion to repair one of these beasts.
Might be similar to the Rivera axles of the day, dunno. Ive seen figures putting the ring gear at over 9" diameter.
One thing for sure. They are totally different than the later Cadillac 8-7/8" axles. Notice the offset of the imaginary centerline of the cover from centerline of the driveshaft.
  #24 (permalink)
Old 09-22-07, 01:43 AM
N0DIH's Avatar
Casino Cash: $9147
Got a link for it?
  #25 (permalink)
Old 09-22-07, 11:51 AM
Casino Cash: $250
Scroll down to the 71-76 blurb.
http://en.wikipedia.org/wiki/Cadillac_Fleetwood
BTW, there IS a 10 bolt with 12 bolt guts too. It was done more than once over the years.
  #26 (permalink)
Old 09-22-07, 04:06 PM
Casino Cash: $7780
check this application chart from motive gear...http://www.motivegear.com/images/art...art.pdf...does this mean i can put anywhere from a 3.08 to a 6.14 gear set in my 75' cadillac limo???( obviously, not that i would even think about putting a 6.14 gear set)
  #27 (permalink)
Old 09-22-07, 04:43 PM
N0DIH's Avatar
Casino Cash: $9147
That would be the Chevy 12 bolt 8.875/8 7/8" axle. I doubt it is compatible with the Cadillac axle. But you never know.
Call Randy's Ring and Pinion and talk to them and see what they know about it.
My guess is the 8.875 axle you have shared the ring/pinion from the Pontiac designed axle gears, which topped out at 3.23, but did go down to 2.41.
  #28 (permalink)
Old 09-22-07, 05:54 PM
Casino Cash: $250
2.93 or 3.15. That's it.
  #29 (permalink)
Old 09-23-07, 04:05 PM
Casino Cash: $7780
Any suggestions on what brand sway bars i should use and what diameters?????
  #30 (permalink)
Old 09-23-07, 07:27 PM
N0DIH's Avatar
Casino Cash: $9147
If you can do some measuring, I might have a bar (it is from a 95 9C1 cop car, I suspect they work on those axles, but need some measurements to confirm)
Tags: , , , , ,
1975, capacity, fleet, fleetwood, towing
