| Re: Another tire thread.... Your tire size should be 225 R75 15. You can use the 215's, but they are a little narrow. The next option is the use of the 235's. The 235' will fit in the wheel wells, no sweat, and they won't rub if your car is set at the standard height. I've used both 225's and 235's. I prefer the 225's, because they work better with the narrow Cadillac wheels. Your Cadiilac wheels are 6" wide, so a wider tire like the 235's won't work as well, especially if you drive it in city driving.
You can use 235's with a 7" wide rim, but that would be a custom rim for a Cadillac. |
