Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > RWD 19xx-1984 DeVille and Fleetwood,
1985-1996 Fleetwood and Brougham Forum
Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille
and Fleetwood, 1985-1996 Fleetwood/Brougham.
Cadillac Forums: 1969 deville rear differential fluid
Old 04-16-07, 04:36 PM
Raider1v1 Raider1v1 is offline
Cadillac(s): Cadillac
View Raider1v1's Photo Album
Casino Cash: $250
Hey guys,
does this fluid need to be changed? and if so with what? in the manual it just says "the special stuff" not the universal fluid. what should i use?
  #2 (permalink)
Old 04-18-07, 01:18 AM
Brother_B's Avatar
Brother_B Brother_B is offline
Cadillac(s): 1969 Cadillac Coupe DeVille
View Brother_B's Photo Album
Casino Cash: $250
Re: 1969 deville rear differential fluid
My manual says to check it and it should be within 1/2" of the lower edge of the filler hole. But that it only should be checked if you've got leakage. It says for the standard differential, to use either SAE 90 multi-purpose type gear lubricant conforming to MIL-L-2105-B or the special stuff . But if you have the Controlled Differential, you _have_ to use the special stuff. Are we looking at the same manual?
  #3 (permalink)
Old 04-18-07, 10:06 AM
Casino Cash: $250
i am looking at the service manual from 69. basically whats the controled differential and where can i get the "special" fluid? i called 4 dealerships and they just told me to use regular 90w gear lube. they didnt have any idea what the controlled one was.
its not a positrack, so i shouldnt need the additive for it right?
  #4 (permalink)
Old 04-18-07, 12:26 PM
JTraik's Avatar
JTraik JTraik is offline
Cadillac Owners Enthusiast
Cadillac(s): '68 DeVille (Restored) '95 FWBrougham '93 Caprice 9C1 (L05)
View JTraik's Photo Album
Casino Cash: $3650
If you dont have a limited slip then you do not need any additives. What I do suggest you do is drill and tap a hole at the bottom of the housing, there is no drain plug for these rear ends. After tapping it you can just stick a bolt with a rubber washer on it and you will be fine.
  #5 (permalink)
Old 04-18-07, 02:36 PM
Casino Cash: $250
why cant i just do it the normal way and just losen the bolts?
sorry side question, when im changing the transmission fluid, i take the pan all the way off right? and then do i need another gasket or seal? or just bolt it back on?
  #6 (permalink)
Old 04-19-07, 03:13 PM
Casino Cash: $250
theres a local transmission place in KC here thats got a special on flushing the transmission for $50. i think that im going to take them up on that, and they can flush the differential for 20.
  #7 (permalink)
Old 04-19-07, 04:02 PM
Motorboat Motorboat is offline
View Motorboat's Photo Album
Casino Cash: $300
Flushing the trans without changing the filter is like kissing your sister. You don't get anything out of it.
You don't flush the rear, you remove the rear diff cover and drain it. Unless you have a leak or hear a growling noise or it breaks, there really is no reason to do this.
  #8 (permalink)
Old 04-19-07, 04:18 PM
Casino Cash: $250
changing the filter is an extra 25. lol i dont want to kiss my sister lol so ill just make sure they do that.
  #9 (permalink)
Old 04-22-07, 12:13 AM
cadillacmike68's Avatar
cadillacmike68 cadillacmike68 is offline
Cadillac(s): 68 DVC, 95 FLTWD, 2000 ELDO, 2005 CTS
View cadillacmike68's Photo Album
Casino Cash: $270
I'm not sure of 69s but my 168 doesn't have a drain plug and it doesn't have a rear cover that you can take off either It has just a fill plug that you would suck the old oil out with a pump and could then refill.
Cadillac limited slip and chevrolet "posi-traction" were two different differentials. I'd have to check my manuals to see if the Cadillac differential needed and special additive, but I don't remember it needing any.
  #10 (permalink)
Old 06-01-07, 11:09 AM
ado2b1 ado2b1 is offline
Cadillac(s): 1969 Sedan Deville
View ado2b1's Photo Album
Casino Cash: $250
hey guys, sorry for the thread jack.
Raider1v1, I just joined and can't send pm's, I live in the KC area and wouldn't mind finding some other owners to meet up with occasionally. Do you know any local groups? I've got a '69 Sedan DeVille.
moderators, I did try to search within the forum but wasn't successful
Tags: , , , ,
1969, deville, differential, fluid, rear
Cadillac Automotive Concepts
bud davis cadillac
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights | air suspension kits | air suspension parts | air ride suspension
