Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > RWD 19xx-1984 DeVille and Fleetwood,
1985-1996 Fleetwood and Brougham Forum
Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille
and Fleetwood, 1985-1996 Fleetwood/Brougham.
Cadillac Forums: Rough Running, Stalling.....
Old 04-08-07, 09:27 PM
DopeStar 156's Avatar
DopeStar 156 DopeStar 156 is offline
"When we ride, it's like an air raid!"
Cadillac(s): 1989 Fleetwood Brougham d'Elegance / 1976 Coupe de Ville
View DopeStar 156's Photo Album
Casino Cash: $7065
My car lately has been stalling after start up, and running rough at red lights at a near stall state. It has no preference of temperature as it does it hot or cold. What do i need to check/replace to fix this annoyance?
‡ DopeStar ‡
  #2 (permalink)
Old 04-08-07, 09:56 PM
N0DIH's Avatar
N0DIH N0DIH is offline
Cadillac Owners Master
Cadillac(s): 94 Fleetwood Brougham
View N0DIH's Photo Album
Casino Cash: $6837
Re: Rough Running, Stalling.....
Look for cracked/broken vacuum lines. PCV is a good one to get hard and crack. Look at all lines under the front/back that go into the baseplate. I am assuming no check engine light. A spray bottle with soap and water in it is helpful to find leaks. Propane torch better. Look for idle change.
Carb is spec'd to be retorqued to intake every 6 months. I haven't found a soul to do it. 10 lb/ft's last I checked, but double check. You can easily damage a carb by overtorquing.
Is cap/rotor in good shape? My 307/350 always seemed to be sensitive to the cap/rotor getting crud on the contacts. I pulled the cap/rotor out and polished up the contacts every 15-25K or so. It always ran great when I did that.
Also look carefully at the cap indexing. I noticed on mine when I would bump up timing it would start to idle rough and it was the ECM that kept timing up so high at idle that the timing would be starting to get off the edge of the contacts. So I installed cap/rotor, drew a paint pen line to line up stock index, then cut off the notch inside the cap to remove the index, and then moved the cap index position to it would recenter the cap/rotor with the contacts. I moved it probably 3/16". It helped a LOT in idle and cap longevity. Only computer controlled engines seemed more sensitive to this.
  #3 (permalink)
Old 04-09-07, 02:06 PM
I~LUV~Caddys8792's Avatar
I~LUV~Caddys8792 I~LUV~Caddys8792 is offline
Cadillac(s): The "Fleetwood Brougham" of Mercedes Benzes...the W140!
Casino Cash: $13462
I bet this has something to do with it sitting in storage so much.....
Forget the Blazer! Use this as your daily driver!!!
-Chad
Those were the days...The Cadillac and The Benz.
Ladies and Gentleman. If I say I'm a car man, you will agree.
Originally Posted by Gary88
I sharted in 8th grade once. I thought I was pulling off a most excellent SBD, but I got greedy.
  #4 (permalink)
Old 04-10-07, 03:08 PM
Casino Cash: $7065
Yeah, then I can sell it as scrap metal in say, a year....
Tags: , ,
rough, running, stalling
Cadillac Automotive Concepts
bud davis cadillac
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights | air suspension kits | air suspension parts | air ride suspension
