RWD 19xx-1984 DeVille and Fleetwood, 1985-1996 Fleetwood and Brougham Forum Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille and Fleetwood, 1985-1996 Fleetwood/Brougham. | Cadillac Forums: Speedometer Showing Wrong MPH
04-06-07, 09:58 PM
| | Cadillac Owners Member Cadillac(s): 1995 Fleetwood vette starter, roadmaster climate control | | Join Date: Jul 2004 Location: Hyattsville MD Age: 30
Casino Cash: $375
| | | Speedometer Showing Wrong MPH My speedo is about 12 mph off, how can I get this fixed. Would the speedo effect the odometer readings as well. |
04-07-07, 03:30 AM
|  | An IT Guy Cadillac(s): 1970 Sedan DeVille | | Join Date: Jul 2005 Location: BC, Canada Age: 20
Casino Cash: $6936
| | | Re: Speedometer Showing Wrong MPH Yes it will affect odometer readings, first you need to figure out why your speedo is off. Are you using non stock sized tires? |
04-07-07, 03:31 AM
|  | Cadillac Owners Enthusiast Cadillac(s): None yet! | | Join Date: Aug 2006 Location: Billerica MA Age: 25
Casino Cash: $5920
| | | Re: Speedometer Showing Wrong MPH Put the factory wheels/tires back on it.
Seriously if you have changed them this will do it quite readily.
If you have the stock size, at least, then you have another issue. Is it a consistant 12MPH? Which direction? Digital dash or analog? |
04-07-07, 07:01 AM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 40
Casino Cash: $10262
| | | Re: Speedometer Showing Wrong MPH On old cars with cable driven speedos, the odo ran off the speedo.
Nowadays the PCM sends pulses to the IPC and the IPC ticks off the miles and runs the speedo based on the same signal.
As stated above, what tire/wheel combo have you got?
Speedos are off by a ratio, that means it is not 12 mph off, but 12 mph off at a given speed. At lower speeds it will be less, at higher speeds it will be more.
Are we talking at 60 mph or something? |
04-07-07, 09:42 AM
Casino Cash: $375
| | | Re: Speedometer Showing Wrong MPH I have the factory tires and rims on there. At 60 speedo reads 48, at 65 its 52. Digital dash. |
04-07-07, 11:04 AM
| | Cadillac Owners Connoisseur Cadillac(s): 1996 Deville (sold), 2000 Mustang GT | | Join Date: Jan 2007 Location: Jersey Age: 24
Casino Cash: $8369
| | | Re: Speedometer Showing Wrong MPH Sounds like you are having a wheel speed sensor failure. Is your traction control and abs working properly?, or do you have any warning lights for either? They both need the speed sensor to be working to function correctly. Did you drive through a deep puddle of water? Thats almost always the reason wheel speed sensors go bad. The fact that your speedo is only a little off,relativelty, makes me think its getting a bad reading from one of the wheels. Hope this helps. |
04-07-07, 12:01 PM
|  | Cadillac Owners Enthusiast Cadillac(s): '68 DeVille (Restored) '95 FWBrougham '93 Caprice 9C1 (L05) | | Join Date: Mar 2004 Location: Rochester, NY Age: 22
Casino Cash: $3650
| | | Re: Speedometer Showing Wrong MPH Are you off by a percentage or off by an integer? Sounds more like a percentage. Did you swap gears in the rearend or anything like that? |
04-07-07, 05:34 PM
Casino Cash: $375
| | | Re: Speedometer Showing Wrong MPH The car is completely stock, the ABS has started to come on once in a while though. |
04-08-07, 03:09 PM
| | Cadillac Owners Fanatic Cadillac(s): 95 FWB | | Join Date: Sep 2004 Location: Texas
Casino Cash: $680
| | | Re: Speedometer Showing Wrong MPH I assume that the pulse is taken from one or more of the detectors on the ABS system. Is this correct? If so, have you tried wire brushing the castellations on the hubs? Some of mine were clogged with disc metal particles.
How are you checking the speed...GPS? |
04-08-07, 03:25 PM
Casino Cash: $375
| | | Re: Speedometer Showing Wrong MPH The speed is being checked by a radar gun. The ABS code is for the front right wheel speed sensor. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
