| Re: 71 Deville heater controls That quote from the the mechanic sounds about right, probably on the lower end. You dont necessarily need a new compressor, you can buy the clutch seperately at just about any parts store, however it is still fairly pricey and difficult to replace without the right tools. Hoses will run you about $70 a piece, the control valve will be about $40. All of these parts can be found at oldairproducts.com... do NOT use their online catalog, use their downloadable PDF catalog oldairproducts.com/shop/pdfcatalog.php... the PDF is MUCH more accurate with part numbers and cross-referencing. I have purchased all of the parts I have mentioned above, from them. Their parts are a little pricey, but very high quality, its worth it.
Now As far as what your describing about the controls not working, it COULD be the control head but more likely the vacuum mechanism that is controlling the flow of air is a little on the fritz. This unit is located on the top of the fiberglass box on the firewall. I would suggest having someone you know look at it or having Tim from cadillactim.com take a gander at it since he specializes in that sort of thing.
- Jeff
