Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > RWD 19xx-1984 DeVille and Fleetwood,
1985-1996 Fleetwood and Brougham Forum
Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille
and Fleetwood, 1985-1996 Fleetwood/Brougham.
Cadillac Forums: Fuel gauge resistance readings?
Old 03-29-07, 05:41 PM
danomac danomac is offline
Cadillac(s): 1981 Cadillac Coupe DeVille
View danomac's Photo Album
Casino Cash: $370
Hey all... new member to this forum.
I have a 1981 Coupe DeVille, and the gas gauge has gone wonky. It reads full most of the time, until it gets to the last 1/2 tank. I have taken my multimeter and testing the sending unit itself, but I have no idea what the resistance values are supposed to be.
I've found a bad ground from the tank to chassey and fixed it by shortening the wire, putting on a ring connector (and soldering it so it won't corrode green again ) but this didn't seem to help at all. The next step would be to test from the gauge->sending unit to see if the resistance values are the same.
Anyone know what the resistance values the sender is supposed to send out?
  #2 (permalink)
Old 03-29-07, 06:31 PM
The Ape Man's Avatar
The Ape Man The Ape Man is offline
Cadillac(s): '80 CDV, '80 Fleetwood Coupe, 1994 Mercedes 140 Coupe
View The Ape Man's Photo Album
Casino Cash: $250
Re: Fuel gauge resistance readings?
I don't have the numbers but you need a new sender. The wiper is not making a connection until the tank gets low.
  #3 (permalink)
Old 03-30-07, 12:35 AM
Casino Cash: $370
Well, I popped the dash pad off and tested the resistance from there to ground on the dash, and it's 180 ohms or so (within 5 ohms of the reading at the back of the car.) I guess it is the sender, but I sure was hoping it wasn't.
The problem is there's no DeVille's in the wrecking yards out here. I'll bet the dealer probably d/c them too (not to mention that'd be $$$.)
I should also mention it thinks there's 1/4 tank left when it's empty - I found this out the hard way.
  #4 (permalink)
Old 03-30-07, 03:27 PM
Casino Cash: $370
I just found a shop out in Langley that can possibly fix it. I gotta yank the thing now and bring it in!
  #5 (permalink)
Old 03-30-07, 08:00 PM
Casino Cash: $370
This time when I removed it I saw the problem; the flat wire inside of the tank that runs from the top of the sending unit down to the actual float lever is garbage. The shop I found said it's repairable and he'll rebuild the thing for $50CAD.
For those around the lower mainland BC the shop is Leakers, tel # 604.626.4558. He refurbishes/renews gas tanks and stuff too. Oh, and he moved his shop to Aldergrove.
Tags: , , ,
fuel, gauge, readings, resistance
Cadillac Automotive Concepts
bud davis cadillac
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights | air suspension kits | air suspension parts | air ride suspension
