Post a pic of your RWD Caddy! - Page 142
Page 142 of 248 FirstFirst ... 42 92 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 192 242 ... LastLast
Results 2,116 to 2,130 of 3714
Like Tree2402Likes
1985-1996 Fleetwood and Brougham Forum Discussion, Post a pic of your RWD Caddy! in Past Cadillac Vehicle Discussion; I had the shaft from mine shortened a local shop did it for 50 bucks with new u joints and ...
  1. #2116
    jcolliga40 is offline Cadillac Owners Fanatic
    Automobile(s): 86 fleetwood
    Oct 2010
    255
    Re: Post a pic of your RWD Caddy!
    I had the shaft from mine shortened a local shop did it for 50 bucks with new u joints and balanced. But I have debated going back to the original tranny which would mean I don't need the adapter plate for the tranny housing. Nothing some black paint can t fix. Or I will probably just end up pulling the bulb. Ya the computer is all confused.
  2. #2117
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    unplug the computer and run a ground wire for the climate control. problem solved
  3. #2118
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,613
    Quote Originally Posted by cadillac kevin View Post
    (just a basic tach, not one of those gaudy super huge ones).
    I see those tachs all the time at the store, the ones that are the size of a steering wheel. I havent seen one hooked up in real life but I just wonder who the hell would buy something like that. Big enough to get pulled over for obstructed view.
    Quote Originally Posted by jcolliga40 View Post
    I am also still having a funky oil color when I drain it. Its grayish not exactly sure why.
    How does your oil pressure seem when its cold and warm? I saw 50psi in the video but thought it seems a little high. Did you use Zinc additive during break in?
    To keep the thread on topic, here's my latest pics in front of the house
  5. #2119
    Oct 2010
    255
    I like the effect those tires give off kind of a hot rod ish look. I didn't add zinc can I still do it the motor has ran for maybe a total of 30 min. Which wire is it that I need to run to ground. There is one under the Hood a black one and seems to arch everytime kit hits the block.
  6. #2120
    Dec 2010
    St. Louis, MO
    6,395
    not sure what black wire you're talking about under the hood (theres a few of them lol)
    the wire you need to run to ground is from the climate control unit (it grounds itself through the engine's computer) I'd have to look in my FSM to see which wire it is.
    once you ground the climate control unit, you can disconnect the computer (thats the only function it still has at this point).
    @csbuckn,
    I have seen 2 of those tachs in real life (odd considering every parts store in town sells them). one on an automatic trans 86 el camino with a plain 305 under the hood, and the other on a hillbillys chevy mud truck from the 80's. both look so out of place and gaudy. you have a tach with about a 6 or 8 inch diameter with a massive yellow shift light sitting up from a hole hacked (and I do mean hacked) in the dash top.
    I'm not sure if you can even still buy a normal sized tach. all I see are these massive "racecar" tachs.
  7. #2121
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Quote Originally Posted by csbuckn View Post
    Those rims look pretty good on that body-style. And it looks a lot better than it would have if you painted the body trim black.
  8. #2122
    Jan 2008
    Minneapolis
    5,613
    You should put some zinc in asap, what oil did you use for break in? Break in should be 20 min at 2k rpm. If the black wire is coming from the passanger side firewall, its "probably" the ecm ground and might be needed for heater controls, I bolted mine to an intake bolt. If its a short wire bolted to the firewall, it goes to the block also and will help with starting the car when its warm.
    Thanks Sven, the look has kinda grown on me. Don't know if I'd go to a chrome rim now.
  9. #2123
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,390
    After a long time , here you go
    talismandave and talismandave like this.
  10. #2124
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,164
    love you fleetwood man! I also like the tire marks at an angle leading right to your back wheel. looks like you did a power slide into that parking spot or something. haha
    Cadillacboy and Cadillacboy like this.
  11. #2125
    SupaFly's Avatar
    SupaFly is offline Cadillac Owners Enthusiast
    Automobile(s): Fleetwood Brougham 1995
    Aug 2003
    Brooklyn
    37
    521
  12. #2126
    Alscad56's Avatar
    Alscad56 is offline Cadillac Owners Fanatic
    Automobile(s): 1956 Sedan Deville,1994 Fleetwood
    Aug 2011
    Les Cedres,QC,Canada
    104
    here are my Cadillacs:
    A 1994 Fleetwood,
    ...and my 1956 Sedan Deville with Eldorado fins ( a special coachbuild order for a funeral home)
  13. #2127
    sven914's Avatar
    Dec 2008
    4,256
    More...
    Please...
  14. #2128
    Alscad56's Avatar
    Aug 2011
    104
    Quote Originally Posted by sven914 View Post
    More...
    Please...
    Here's one of the interior:
    Sorry, I couldn't upload more pics. Seems like they exceed the quota limit, even though they are not large files.
  15. #2129
    Dec 2003
    36
    4,390
    Quote Originally Posted by outsider View Post
    Thanks
    LOL, I had not thought like that for these tire marks , I mean powersliding ha ha .
  16. #2130
    Alscad56's Avatar
    Aug 2011
    104
    Ok, here are more....
  17. Remove Advertisements
