Need part number and price for an O2 sensor.
Results 1 to 4 of 4
Rippy Cadillac Discussion, Need part number and price for an O2 sensor. in Authorized Cadillac Vendors; The sensor is (Bank 1 Sensor 2) which is the downstream sensor im pretty sure. Any idea on the part ...
    TunixComplex is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS 3.2 5M
    Jan 2010
    Springfeild, MO
    27
    614
    Any idea on the part number or a price?
    VIN: 1G6DM57N230111158
    Thanks
    Also... im throwing a lot of U1000 codes could my ECM be dieing? I clear the codes and then the check engine light comes back on minutes later with the same P0138 (O2 sens.) and U1000. Im going to check all fuses tonight as Ghetto said the U1000 could be a blown fuse as he had the same issue with a blown alarm fuse.
    Quick reply to this message Reply
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Need part number and price for an O2 sensor.
    both Bank 1 Sensor 2 and Bank 2 Sensor 2 (post-cat. aka downstream) sensors are the same
    GM#24402860
    $121.84 - list price
    $ 76.15 - your price
    i've got one in stock
    as for the U1000 could be a low powered or dying battery ... or a loose connection ... the ECMs are known to go bad on the early 1st Gen CTS's ... either throwing phantom O2 codes or grabbing the key and not letting go
    fuse could also be a cause since the U code is a communication error code and if they fuse is blown that module will not communicate and you will then get the U code
    Jan 2010
    Springfeild, MO
    27
    614
    Thanks, I looked at the fuses but couldnt find much. Whats the part number for an ECM?
    Sep 2007
    Wilmington, NC
    13,986
    2003 CTS (3.2L) ECM
    #12581155
    $460.92 - list price
  7. Remove Advertisements
  • You may not post replies
