2005 DeVille Rear Springs, so many choices???
Results 1 to 4 of 4
Rippy Cadillac Discussion, 2005 DeVille Rear Springs, so many choices??? in Authorized Cadillac Vendors; [FONT=trebuchet ms]Rippy, I find this when trying to gain insight into the differing springs available: [/FONT][TABLE="class: part_list"] [TR] [TD="class: td1"]21[/TD] ...
    thedill's Avatar
    thedill is offline Cadillac Owners Member
    Automobile(s): 2005 DeVille
    Feb 2012
    Manhattan, KS
    62
    [TR]
    [TD="class: td2"]**670966[/TD]
    [TD="class: td3"]SPRING RR,(CODE:PCF)[/TD]
    [TD="class: td4"]KD,KE,KF (8CC, 8CD, 8CF, 9CC, 9CD, 9CF)[/TD]
    [TD="class: td5"][/TD]
    [TD="class: td6"][/TD]
    [TD="class: td7"][/TD]
    [TD="class: td8"][/TD]
    [TD="class: td9"][/TD]
    [TD="class: td10"][/TD]
    [TD="class: td11"][/TD]
    [/TR]
    [TR="class: grayline"]
    [TD="class: td2"]**670967[/TD]
    [TD="class: td3"]SPRING RR,(CODE:PCH)[/TD]
    [TD="class: td4"]KD,KE,KF (8CH, 8CJ, 9CH, 9CJ)[/TD]
    [/TR]
    [TR]
    [TD="class: td2"]**655473[/TD]
    [TD="class: td3"]SPRING RR,(CODE:NCR)[/TD]
    [TD="class: td4"]KD(69) (8FD, 9FD)[/TD]
    [/TR]
    [/TABLE]
    [FONT=trebuchet ms]
    [/FONT]Why 3 different part numbers?
    What are: "PCF," "PCH," and "NCR"
    What are: all the other nomenclature?
    What about all these??
    [TD="class: td1"]39[/TD]
    [TD="class: td2"]**689199[/TD]
    [TD="class: td3"]SPRING RR,(MAX LOAD 8817.6 /MIN LOAD 2692.0)[/TD]
    [TD="class: td4"]KD (FE7)[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: td2"]**689201[/TD]
    [TD="class: td3"]SPRING RR,(CODE 9201),(58/10125 RATING)[/TD]
    [/TR]
    [/TABLE]
    [TD="class: td2"]**698884[/TD]
    [TD="class: td3"]SPRING RR,(MAX LOAD 9157.8 /MIN LOAD 3232.0)[/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: td2"]**731658[/TD]
    [TD="class: td3"]SPRING RR,(27/4600 RATING)[/TD]
    [/TR]
    [/TABLE]
    etc.
    what does "27/4600 RATING" mean?
    I am guessing that the "39**xxx" part numbers are for limo/hearse applications as the diagram shows a 6lug wheel?
    What am I getting at - wondering about stiffer rear springs, I have a 'base' model. Is there a way to get a spring stiffness value from the listings?
    From what I think I know there are:
    - base/DHS springs - these are 'soft'
    - Touring/DTS springs - these are 'firmer'
    - limo / hearse springs - I'd guess these are stiff as 'a board'
    Quick reply to this message Reply
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: 2005 DeVille Rear Springs, so many choices???
    ok so where to start...
    the 'code' listings are another designation that should be on a tag on the spring
    kind of used for extra verification since with a VIN number in the parts catalog it should only show one of those
    KD, KE, KF are body style codes for devilles (KS, KY are sevilles)
    KD is regular deville
    KE is luxury deville (DHS)
    KF is touring deville (DTS)
    the codes after the body style are the RPO (regular production options) codes
    that's how the parts catalog filters the parts out that don't fit the vehicle
    FE7 is the heavy duty suspension (limo/livery) RPO code
    i'm not really familiar with the descriptions and ratings that are given there though
    as far as I understand these suspensions the springs are used to hold up the vehicle's weight and while they can affect the ride the shock/strut dampens the spring's oscillation
    the spring rates on the limo are more varied because the weights can be much different
    the spring rates on the Deville/DHS/DTS are going to be the same (they take the same springs actually) because they weigh about the same
    the shocks and struts change the stiffness in this application
    if you put a limo spring on a regular deville the spring wouldn't be able to oscillate that much since it's much stiffer and the weight of the regular deville doesn't make it compress much so there's not much travel that the shocks and struts have to dampen (if they can - they might not be strong enough to deal with the stiffer springs)
    basically what i'm getting at is that these suspensions are not meant to be modified
    if you are having a problem you should rectify it with the correct repair
    thedill's Avatar
    Feb 2012
    Manhattan, KS
    62
    [FONT=Trebuchet MS]Excellent, thanks Chris. That's very good info.[/FONT]
    Sep 2007
    Wilmington, NC
    13,986
    no problem
  7. Remove Advertisements
  • You may not post replies
