Results 1 to 10 of 10
Thread: 97 Eldorado ETC 127,1xx miles
    97EldETC's Avatar
    97EldETC is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Eldorado ETC
    Dec 2011
    Sunny and Coastal California
    490
    I had my oil light flicker just below 1 rpm yesterday. Hasn't done it since at same rpm, so everyone else here says I need a new oil switch and o-rings. How much to ship these out to bay area California?
    Sep 2007
    Wilmington, NC
    13,969
    Re: 97 Eldorado ETC 127,1xx miles
    switch
    #12635958
    $10.04
    orings
    #3543719
    $2.78 x2 = $5.56
    shipping
    $13.00
    TOTAL
    $28.60
    all in stock currently
    97EldETC's Avatar
    Dec 2011
    490
    Thanks I'll get back to you on that. But I want to ask you; since I am replacing the bad oil switch, what is the point in changing the o-rings? The other Seville/eldorado owners say I should and I'm not sure why. What's your opinion?
  5. #4
    Sep 2007
    Wilmington, NC
    13,969
    It's easier to get the switch off by taking the oil filter adapter off first then removing the switch from the adapter
    that's the usual repair strategy that people recommend here
    the o-rings go between the block and the adapter
  6. #5
    97EldETC's Avatar
    Dec 2011
    490
    [QUOTE="RippyPartsDept"]It's easier to get the switch off by taking the oil filter adapter off first then removing the switch from the adapter
    the o-rings go between the block and the adapter[/QUOTE]
    So do I need to buy the o-rings or can I just use the current one(s)? Also my plastic trim on the driver seat (left side) that has the power seat adjustments is broken at the front of the seat. It kind of waves around. If you know what I mean. It runs from the front of the seat to the back (the trim). How much to get this part? The seat will move but not fully in all directions unless I push the buttons really hard back against the seat...
  7. #6
    Sep 2007
    Wilmington, NC
    13,969
    for $5.56 it's pretty cheap insurance that you won't need to do the job twice
    i'll need your VIN to make sure i look up the right trim piece ... can you PM it or just post the last 8 digits here?
  8. #7
    97EldETC's Avatar
    Dec 2011
    490
    Vu601451
  9. #8
    Sep 2007
    Wilmington, NC
    13,969
    Sorry to say but it's discontinued. Salvage yards are your friend. If you need I can recommend a place or two.
  10. #9
    97EldETC's Avatar
    Dec 2011
    490
    [QUOTE="RippyPartsDept"]Sorry to say but it's discontinued. Salvage yards are your friend. If you need I can recommend a place or two.[/QUOTE]
    Great... Yes please do. I'm in the easy bay CA
  11. #10
    97EldETC's Avatar
    Dec 2011
    490
    Well I emailed Cadillac heaven. So I'll see about their reply too.
  • You may not post replies
