Order
Results 1 to 4 of 4
Rippy Cadillac Discussion, Order in Authorized Cadillac Vendors; Hey Installing V series front sway bar on my 05 1SG and the yard only sent me one of the ...
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Order
    Hey
    Installing V series front sway bar on my 05 1SG and the yard only sent me one of the brackets.
    I need one of these I believe the part number is 10364742.
    How much shipped for one of these and how long till you can get it. Thank you!
    Quick reply to this message Reply
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Order
    It looks to me like that bracket/clamp part number is the same for the V-series and for the standard STS sway bars
    I know typically the sway bar will get thicker for the higher performance suspension, but just in case, have you compared the one you got to your originals?
    The shipping will depend on how far you are away from us (a zip code would probably be best to get a shipping quote).
    The part itself will cost you $19.00 and take about 5 days for me to get from GM (then we'll ship it to you so add some more time for UPS ground - again depending on how far away you are).
    Hope that helps. Let me know if you've got any other questions.
    ~Chris
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Re: Order
    From what i was able to pull the standard STS has a different brace number and when looking they did look different. The V seems to share the same part number as the SRX though.
    Sep 2007
    Wilmington, NC
    13,986
    Re: Order
    Ok, I drilled down a bit deeper and found that this part number fits:
    2006-2009 STS-V
    2009-2011 STS
    2004-2009 SRX
    AND the 2011 CTS4 (AWD) Wagon
    Which explains why at first glance it seemed to fit both the regular and the V-series
    so, what's your zip code? i can then get you a quote on shipping...
    also, 4pm is our cutoff time for getting parts ordered that same day
  7. Remove Advertisements
  • You may not post replies
