Revshift Trans Mount Inserts
Results 1 to 3 of 3
Revshift Performance Engineering Discussion, Revshift Trans Mount Inserts in Authorized Cadillac Vendors; Don't spend hundreds of dollars on a questionable aftermarket trans mount when you can convert your oem mount to a ...
    Revshift is offline Cadillac Owners Fanatic
    Automobile(s): none
    Apr 2011
    Warren, MI
    258
    Don't spend hundreds of dollars on a questionable aftermarket trans mount when you can convert your oem mount to a high performance mount with this insert for a fraction of the cost.
    The trans mount insert is made from high quality polyurethane with an 80A hardness. It was molded to perfectly match the inside of a brand new OEM transmission mount. It will significantly stiffen the OEM trans mount creating less slop in the driveline. It will also prevent sagging and drastically extending the life of the OEM mount.
    https://www.revshift.com/shop/bushin...s/cadillac.php
    Quick reply to this message Reply
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    Re: Revshift Trans Mount Inserts
    Interesting. How is it installed?
    Automobile(s): none
    Apr 2011
    Warren, MI
    258
    Quote Originally Posted by HAMSTAR View Post
    It presses in. You can use a bench vise, a big C-clamp, someone with very strong hands, or an actual press. Its a tight fit but its pretty easy to install.
  • You may not post replies
