R1 Concepts| R1 FORGED SERIES BIG BRAKE KIT!
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By AAIIIC
R1 Concepts Discussion, R1 Concepts| R1 FORGED SERIES BIG BRAKE KIT! in Authorized Cadillac Vendors; R1 Forged Series Big Brake Kit! "Maximizing brake performance to the highest level! R1 Forged Series Big Brake Kit is ...
    r1concepts's Avatar
    r1concepts is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Dec 2006
    Cerritos, CA
    256
    R1 Forged Series Big Brake Kit is made for those seeking maximum performance in braking. R1 Forged Series Brake Rotors are manufactured with High Carbon (more Carbon, Chromium, and Molybdenum), the R1 Forged Series Brake Rotors offers increased braking performance and strength. A center split core castinf provides greater stability. Black Electro Coating protects against rust while extended rotor life. Mill balancing and double disc grinding reduces thickness variations for smoother stopping, minimal vibration and improved break-in.
    *AVAILABLE IN DRILLED ONLY, SLOTTED ONLY, OR DRILLED & SLOTTED
    Calipers
    • Forged Aluminum 6061 T6
    • Available in 4 piston, 6 piston, and 8 piston
    • Available in paint or anodized in a variety of colors (both with clearcoat)
    Rotor Hat
    • Aluminum 6061 T6
    • Black Hard Anodized (Standard)
    • Available in a variety of anodized colors
    • 2 Piece (Standard)
    • Floating (Upgrade)
    Rotors Sizes
    • 330mm (12.99") FRONT/REAR
    • 345mm (13.58") FRONT
    • 356mm (14.02") FRONT/REAR
    • 380mm (14.96") FRONT/REAR
    • 405mm (15.94") FRONT
    Pistons
    • Aluminum (Standard)
    • Stainless Steel (Upgrade)
    • Knockback Springs available (Upgrade)
    *IF YOU HAVE ANY QUESTIONS OR ARE INTERESTED IN PURCHASING, PLEASE PM OR EMAIL KEVIN@R1CONCEPTS.COM*
    Kevin - Sale Rep
    R1 Concepts Inc.
    Kevin@r1concepts.com
    888-712-6623 ext. 7022
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,306
    Re: R1 Concepts| R1 FORGED SERIES BIG BRAKE KIT!
    Who makes the calipers? For cars that use a drum brake inside the rear disk for the parking brake (like my Subaru), do the rear kits maintain that setup, or how does the parking brake work?
    What makes the R1 Forged brake kit better than a kit from more established BBK manufacturers like Baer or Stoptech?
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    r1concepts's Avatar
    Dec 2006
    Cerritos, CA
    256
    Quote Originally Posted by AAIIIC View Post
    We engineer and design the calipers ourselves and have our own manufacture for our BBK. Yes, you would still retain your parking brake. We offer a iron disc ring at an additional cost that attaches to the hub of the BBK rotor hat that functions the same as your stock parking braking. Comparing our BBK to other manufactures such as Baer or Stoptech, functionality it's the same for most BBK calipesr out there on the market. We compare our R1 BBK in line with Stoptech. Not only that, all of our kits are made to order. Depending on what you need it for, race or everyday driving, you can customize it any way you want. From aluminum or stainless pistons, knockback springs, fixed to floating rotors, different brake pad formulas to even custom colors of paint or anodized.
    Kevin - Sale Rep
    R1 Concepts Inc.
    AAIIIC's Avatar
    Aug 2007
    6,306
    Thanks for the response. Good to have another player in the market. I'll definitely be looking at your options when I get my Subie back on the road this year.
    r1concepts likes this.
    r1concepts's Avatar
    Dec 2006
    Cerritos, CA
    256
    Weekend bump
    Kevin - Sale Rep
    R1 Concepts Inc.
    r1concepts's Avatar
    Dec 2006
    Cerritos, CA
    256
    Weekend bump
    Kevin - Sale Rep
    R1 Concepts Inc.
  9. Remove Advertisements
