| Other Cadillac Engines This forum is to discuss Cadillac engines not listed in other forums. | Cadillac Forums: 1964 429cid valves and lifters - where to buy
10-25-05, 01:56 PM
|  | Cadillac Owners Enthusiast Cadillac(s): ´67 Eldorado, ´96 Eldorado, 97 Wrangler | | Join Date: Apr 2003 Location: Tallinn, Estonia Age: 40
Casino Cash: $3527
| | 1964 429cid valves and rockers - where to buy Opened engine heads in my new toy today and 4 valves are bad  and all engine covered inside with some f**** grease. Unbelievable - who does sutch things
Long story, but anyway i need 4 new valves and rockers.
So can you guys give advice, where to buy? I need to ship them fast too (so its UPS probably?). I tried to contact Maddog Racing in Florida, but seems, that their web page is down
10-25-05, 06:13 PM
|  | Banned Cadillac(s): 1976 Eldorado project | | Join Date: May 2005 Location: El Dorado, Arkansas Age: 18
Casino Cash: $250
| | | Re: 1964 429cid valves and lifters - where to buy Just curious, what's wrong with these 4 valves? What is wrong with the lifters? Just trying to get some more information.
I'm sure Al at MTS would have what you need. www.500cid.com |
10-26-05, 09:28 AM
Casino Cash: $250
| | | Re: 1964 429cid valves and lifters - where to buy Pictures help a lot. I'm no expert on heads or anything, but if you look at the pushrods and can't see through them (they are hollow for oil to travel through to get to the rockers) then they are clogged with the stuff, and you will need new ones unless you can unclog them. However, if they are clogged up they are probably what's causing the lack of oil and offer a pretty easy solution to the oil delivery problem. www.500cid.com e-mail Al, he will probably have pushrods for you and possibly rockers that will work or that are just laying around if you need them.
Lifters can be found on Summit and on Ebay. Manley intake and exhaust valves on Ebay: http://cgi.ebay.com/ebaymotors/S1580...QQcmdZViewItem http://cgi.ebay.com/ebaymotors/A1581...QQcmdZViewItem |
10-26-05, 11:34 AM
|  | Cadillac Owners Connoisseur Cadillac(s): '80 CDV, '80 Fleetwood Coupe, 1994 Mercedes 140 Coupe | | Join Date: Feb 2005 Location: Southern NJ Age: 46
Casino Cash: $250
| | | Re: 1964 429cid valves and lifters - where to buy The Grey stuff could be lead deposits. Treat it like toxic waste. The valves cannot be changed without removing the cylinder heads. You must make sure that there is enough oil pressure to stop this from happening again. If the inside of the oil pan looks like the top of the engine then you may have problems there also. Might be time to pull the engine out for inspection. |
10-26-05, 11:55 AM
Casino Cash: $3527
| | | Re: 1964 429cid valves and lifters - where to buy Thanks guys,
Engine is pulled out, same with heads, also opened bottom and few bearings - they are OK.
Oil pan is also clean exept oil, what is probably same age, that car(i always wonder why people dont change oil as supposed). As i opened engine, i probably change oil pump and water pump as well. But question: i think it will be wise change all valves in same time, also valve seats - am i right?
And, are there any difference between 1959...65 and 1966..67 valves? Looks like they are sold in different prices??? http://cgi.ebay.com/ebaymotors/A1277...temZ4548663837
vs. http://cgi.ebay.com/ebaymotors/A1581...temZ4554716743
I have 1967 Eldorado too, but i never opened this engine.
10-27-05, 08:58 AM
Casino Cash: $250
| | | Re: 1964 429cid valves and lifters - where to buy Yes there is a difference between valves. Get the ones correct for your year. I don't know much about heads, etc. But I would change the valve seats just to be safe. Once again I don't know what kind of wear they experience, etc.
Don't know what a lead deposit is. Care to explain Ape? |
10-27-05, 02:48 PM
Casino Cash: $3527
| | | Re: 1964 429cid valves and lifters - where to buy OK, Al cant help me, but Maddog can, so lets see, what they offer.
I think, its good to change valve seats, as heads are off - unleaded fuel isnt good for those old seats. |
10-27-05, 07:59 PM
Casino Cash: $250
| | | Re: 1964 429cid valves and lifters - where to buy Right on. |
10-28-05, 10:09 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 93 Coupe DeVille, 94 Deville, 2000 STS | | Join Date: Jan 2003 Location: Portland, ME Age: 27
Casino Cash: $1377
| | | Re: 1964 429cid valves and lifters - where to buy Try Egge for engine parts. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
