429 Engine
Results 1 to 8 of 8
Other Cadillac Engines Discussion, 429 Engine in Cadillac Engine Discussion; hello guys. i just got a 1965 deville and i must replace the exhaust. it's broken and rusted. what is ...
    deville1965 is offline Cadillac Owners Member
    Aug 2005
    429 Engine
    hello guys. i just got a 1965 deville and i must replace the exhaust. it's broken and rusted. what is the best pipe size for this cadi. it has 429 ci. more power and sound needed. and if you know any place sell parts for this car, headers, lowering kit, and body parts.
    95Concours's Avatar
    95Concours is offline Expired eMail Address
    Jan 2004
    43
    121
    Re: 429 Engine
    I used to own a 64 deville with the 429. Mine was kept stock so im not sure about performance parts. But if you need parts, I used to use www.caddydaddy.com. They are a bit pricey on some things, but they usually have hard to find parts.
    Aug 2005
    Re: 429 Engine
    thank you bro.. i'll check it out.
    cadillac dan is offline Cadillac Owners Member
    Mar 2004
    Oldsmar, Fl
    3
    Re: 429 Engine
    I have a 1964 Fleetwood with the 429. When I was rebuilding it, I found "USA Parts Supply Ltd to be a good source. They can be reached at 703.335.1935, or www.usapartssupply.com. Stock parts only.
    Mar 2004
    Oldsmar, Fl
    3
    Re: 429 Engine
    I used parts obtained from USA Parts Supply when I was rebuilding the motor in my 64 Fleetwood. Contact them at 703.335.1935, or www.usapartssupply.com. Stock parts only.
    luther is offline Cadillac Owners Member
    Automobile(s): 75 coupe de ville , 76 sedan de ville.
    Nov 2006
    ont. canada
    51
    6
    Re: 429 Engine
    I just replaced the exhaust on my 65 coupe de ville, did it myself, it had single exhaust . I cut the pipes just after the manifolds on both sides got some 2" pipe and a couple of cherry bombs, exited the pipes just after the doors on both sides, and presto ! cool dual exhaust, sounds great , looks great , performs great, if your inclined and have acess too a set of torches..
    Maxb49 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2007
    76
    Re: 429 Engine
    Run a supercharger setup for a 460 c.i.d. Ford on your 429. An adapter kit available to execute this project.
    CTS-Voodoo's Avatar
    CTS-Voodoo is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Raven V
    Oct 2008
    AutoRepairSEO.com
    951
    Re: 429 Engine
    I ran 2 1/2 inch duals on mine back when I built the engine on the old 65. If youre going to get into modding this motor, know that it costs a friggin fortune to have custom parts made. Most obvious mod setup is a 650 carb with dual exhuast and a K&N. If you want more, it gets a little nuts.
  11. Remove Advertisements
