Seville SLS 1999 engine starts bad and going first time out
Results 1 to 2 of 2
Other Cadillac Engines Discussion, Seville SLS 1999 engine starts bad and going first time out in Cadillac Engine Discussion; Hello at all, sorry for my bad english, because i live in germany and have a big problem with my ...
    JensM is offline Cadillac Owners Member
    Automobile(s): Seville SLS
    Jul 2009
    1
    Hello at all,
    sorry for my bad english, because i live in germany and have a big problem with my caddy wich i bought 4 months ago.
    If i want to start the engine normally, the rpm ist so low and rides up and down, that the engine stops the work. At the second or third try the machine works...sometimes i drive for example on the highway and the motor stops to work...not so well.
    The first time i think that there are problems with the LPG-system...but the problems begins, when the engine ist starting with normal petrol.
    Does everyone know, what is to do? The engine have 114000 mls running and i think the first spark plugs - will these be a matter?
    Greetings Jens
    97EldoCoupe's Avatar
    97EldoCoupe is offline Owner of Northstar Performance
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    The Great White North
    31
    2,628
    Re: Seville SLS 1999 engine starts bad and going first time out
    A Caddy on LPG? LPG is cheap fuel: this would be perfect for my N* powered truck project. Any pics on the LPG system or info on where it was installed? Also please pull the codes, maybe there's something that can help us pinpoint the problem.
