| Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.). | Cadillac Forums: a bunch of problems
02-21-07, 03:28 PM
|  | Cadillac Owners Enthusiast Cadillac(s): Ex-99 Deville owner, Now-04 DTS owner, and a 07 ZX6R pilot | | Join Date: Nov 2005 Location: Silver Spring, MD Age: 27 | | | a bunch of problems I have a 99 Deville. Everytime i drive this car, I find something new. I did some searches and found my sway bar thing might be loose. But that's not my problem. I'm in NYC and recently it snowed. Snows gone but it left me with some problems. My traction control is overly precautious now. I had a traction control light. I cleared it, never came back. After that though, every time I leave a light, my traction control engages for a couple seconds. Pisses me off. And on top of that, everytime I'm at idle or turn off the car, I hear bubbles coming from under the dash, probably from heater coil. I checked though and the coil isn't leaking. I got air in the coolant system somehow. I did the headgasket leaking check when you take off the coolant cap and check for bubbles. No bubbles. I think I may have a leak somewhere though because I had to add coolant 2 weeks ago. How do I get these bubbles out of my coolant system. It sounds like an aquarium. |
02-21-07, 05:24 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: a bunch of problems The engine is designed to purge itself of air in the cooling system. Check the purge line to be sure it is clear and flowing. |
02-21-07, 05:32 PM
| | Cadillac Owners Connoisseur Cadillac(s): 94 ETC,97 STS | | Join Date: Sep 2003 Location: Arizona | | | Re: a bunch of problems If the purge line is clear have a coolant byproduct (exhaust gas) test done at a radiator shop.
If it passes that you can do the normal diagnostics.
If it fails that you save a lot of time, you'll know it's head gaskets. |
02-21-07, 09:54 PM
|  | Cadillac Owners Enthusiast Cadillac(s): Ex-99 Deville owner, Now-04 DTS owner, and a 07 ZX6R pilot | | Join Date: Nov 2005 Location: Silver Spring, MD Age: 27 | | | Re: a bunch of problems Thanks for the replies! Anyone know why my traction control engages at every light on dry pavement? |
02-21-07, 09:57 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: a bunch of problems Maybe a bad wheel speed sensor. Any codes? |
02-22-07, 09:20 AM
|  | Cadillac Owners Enthusiast Cadillac(s): Ex-99 Deville owner, Now-04 DTS owner, and a 07 ZX6R pilot | | Join Date: Nov 2005 Location: Silver Spring, MD Age: 27 | | | Re: a bunch of problems The first thing I did was check for codes. No codes. It baffles me. |
02-22-07, 12:09 PM
|  | Cold Soaked Cadillac(s): 2006 STS AWD, '95 Ford Ranger | | Join Date: Jul 2004 Location: Fairbanks, Ak Age: 70 | | | Re: a bunch of problems Maybe badly matched tire sizes or a low tire.
__________________ Don't mess with Binky Bear! |
02-22-07, 01:49 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 01 Eldo ETC, 02 Deville | | Join Date: May 2004 Location: Salem, NJ Age: 56 | | | Re: a bunch of problems Quote:
Originally Posted by 99Classillac Thanks for the replies! Anyone know why my traction control engages at every light on dry pavement? |
My '99 used to engage T/C very often when pulling away from a stop in wet and damp weather - it was a faulty wheel speed sensor. Never bothered to repair it. It didn't do it in dry weather though, so that sounds a bit of a puzzler...
"For a successful technology, reality must take precedence over public relations, for Nature cannot be fooled." - Richard P. Feynman  |
02-23-07, 02:07 PM
|  | Cadillac Owners Enthusiast Cadillac(s): Ex-99 Deville owner, Now-04 DTS owner, and a 07 ZX6R pilot | | Join Date: Nov 2005 Location: Silver Spring, MD Age: 27 | | | Re: a bunch of problems Yea this thing irritates me. i stopped driving it and drive my impala now. i hate my impala but it doesn't have any problems because it's brand new. Got it for the wife. Shoulda bought another cadillac. But I checked codes again and no codes. It still engages the TC. It makes a bad clicking sound like something is rubbing and then the DIC says traction engaged. I checked tires, they are fine. I'm stumped. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
