Go Back   Cadillac Owners Group > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: 96 Cadillac ETC, Idle Problems
Old 01-28-07, 07:57 PM
Nana600 Nana600 is offline
Cadillac(s): Cadillac
View Nana600's Photo Album
Casino Cash: $250
Have a 96 ETC. It has been in 2 shops this month one being the cadillac dealership. The car will run away with you like the cruise control is on.when stopped at a light it will rev up like its going to blow up.Also wants to lunge forward on its own. Both places changed the same part the idle sensor. That works for about 20 miles then its right back to the same thing again. Knowing nothing about the northstar engine and being female I did unplug this wire from a round silver Cylinder and car runs fine as long as this thing is unpluged.
  #2 (permalink)
Old 01-28-07, 09:01 PM
Ranger Ranger is online now
View Ranger's Photo Album
Casino Cash: $15011
Re: 96 Cadillac ETC, Idle Problems
Sounds like you are talking about the ISC (Idle Speed Control) motor. You said they replaced it? Have you pulled the codes? There may be a DTC (Diagnostic Trouble Code) stored that will give us a clue.
  #3 (permalink)
Old 01-28-07, 11:07 PM
Casino Cash: $250
They hooked something to the computer in the car at both places. But it says the same thing everytime . Like today when it happened and I just got the car back saturday night. Service engine light comes on and message says service idle control, New idle sensor was put in at both places. Do you know if this could have any thing to do with catalistic converter or the throttle closed sensor in the servo motor. I just happened to read that on someone elses problem but it wasn't a eldorado. I got this car from my Mother it had been sitting up in a garage and only has 25000 miles.
  #4 (permalink)
Old 01-28-07, 11:12 PM
Cad tech's Avatar
Cad tech Cad tech is offline
Cadillac(s): 03 STS, 97 STS, 58 Eldo
View Cad tech's Photo Album
Casino Cash: $250
This will have an idle air control motor, if you have had it replaced 2 times there has to be a circuit problem or pcm problem I would bring it back to Dealership and tell them they did not fix the problem and they have already charged you for a repair that did not fix original complaint and you expect it to be repaired at no cost to you.
  #5 (permalink)
Old 01-28-07, 11:22 PM
Casino Cash: $250
Will call dealership in the morning . I think they should to being they cherged me 312.00. But tell me what is the pcm.
  #6 (permalink)
Old 01-28-07, 11:35 PM
CadillacSTS2003's Avatar
CadillacSTS2003 CadillacSTS2003 is offline
AKA CadillacETC1997
Cadillac(s): 03 STS, 97 ETC, 98 STS, 06 STS-V, 74 Eldo Vert, 05 STS=RIP
View CadillacSTS2003's Photo Album
Casino Cash: $7600
powertrain control module
basically the computer that runs the engine...
  #7 (permalink)
Old 01-28-07, 11:37 PM
Cad tech's Avatar
Casino Cash: $250
Cannot tell without seeing Invoice...see what the tech comments are and what they replaced..Remember if they dont fix the problem dont be scared to turn right around or call them.dont let it go on for a while...and if the service advisor is unresponsive ask for service manager or general manager....
  #8 (permalink)
Old 01-28-07, 11:51 PM
Casino Cash: $250
28466 Bad Throttle Position Sensor j6374+A 2.0 Found codes PO122,1122set. Checked and found erratic reading from TP Sensor. Checked TP Connector and terminals. Tested circuits to TP Sensor All Check ok. Replaced TP Sensor, Cleared Codes and road tested ,operating as designed. That is what the report says. They also did Engine Fuel Rail that was a recall on this auto.
Tags: , , ,
cadillac, idle, problems
Cadillac Automotive Concepts
bud davis cadillac
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights | air suspension kits | air suspension parts | air ride suspension
