| 99 deville with a missfire I have a missfire that I cant seem to find the problem with.
This is what I have done so far. Changed plugs, wires, coils, ignition module, injectors. Checked compression was good. smoked the motor for any intake leaks without finding anything, pulled the vavle cover and checked the cam lobes and also checked to make sure the valves were opening and closing, checked vavle springs and looked good. After that I pulled the intake off just incase we missed something. Didnt find any problems and reinstalled that with new gaskets. The problem is still there and is only on cylinder 6. I notice it more just at idle seems to go away with more fuel. I've searched on the forum here for a bit and the only thing I found that I havnt tried was a ground cable going to the coil pack. Also metion there are no codes. |
