Go Back   Cadillac Owners Group > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Honestly, is a Northstar Cadillac a wise purchase for a ~20 year old?
  #31 (permalink)
Old 01-23-07, 09:03 PM
I~LUV~Caddys8792's Avatar
I~LUV~Caddys8792 I~LUV~Caddys8792 is online now
Cadillac(s): The "Fleetwood Brougham" of Mercedes Benzes...the W140!
Casino Cash: $13427
Re: Honestly, is a Northstar Cadillac a wise purchase for a ~20 year old?
Blunted, yours sounds like the nightmare, worst case scenario Northstar Cadillac I was referring to earlier, it seems that everythign that could go did go, plus more. I bet not more than 4% of all Caddies go that bad, but since all that happened, your input is that much more worthy to me.
-Chad
Those were the days...The Cadillac and The Benz.
Ladies and Gentleman. If I say I'm a car man, you will agree.
Originally Posted by Gary88
I sharted in 8th grade once. I thought I was pulling off a most excellent SBD, but I got greedy.
  #32 (permalink)
Old 01-24-07, 10:20 AM
blunted blunted is offline
Cadillac(s): '94 Eldorado , '05 V8 STS
View blunted's Photo Album
Casino Cash: $5407
Originally Posted by bcs296 View Post
A&B solenoids are NOT an expensive repair. .
True.. that is IF you actually find a decent shop that wont try to kill you on the price. When mine went everyone wanted $450+.. and the dealership wanted to pull the tranny. I was screwed until a fellow local caddy member on the board saved my ass and did it for me.
  #33 (permalink)
Old 01-24-07, 08:24 PM
blb blb is offline
View blb's Photo Album
Casino Cash: $331
Originally Posted by blunted View Post
- Entire suspension started going out.. had to replace everything (struts,mounts,linkss,bushings, ball joints)
-Stupid stuff started breaking.. Oil filter adapter, oil switch,sensor
- A&B Solenoids went on the tranny
- Very bad half-case leak.. makes alot of smoke
- Coils/Plugs blowing
- Radiator Went
- Engine/Tranny Mounts have gone bad
- My brake lines now need replacing
-Car squeaks unexplainably
-Panels warping
Been there, done that, with the brake lines. Its interesting that my 16 year old beater import has the brake lines coated in plastic so they won't rust but my babied GM Flagship STS with only 56,000 miles had metal brake line failures. What kind of garbage metal are they made of that they rust so quickly?
Other items that typically need attention around or before 100,000 miles on these are the A/C compressor bearing (most places typically want to replace the entire compressor instead of replacing just the bearing), water pump, alternator, (PITA to replace), power window motors, CD player (if equipped), serpentine belt idler pulley, tensioner pulley and front hub bearings.
If you can do the work on these items yourself and you have the time, go for it. If you have to pay someone else to do it, it can get prohibitively expensive very quickly. These cars just won't go 200,000 miles with most of the original parts like many of the imports will.
  #34 (permalink)
Old 01-24-07, 08:34 PM
Casino Cash: $13427
Or anything with a 350 or 3800
  #35 (permalink)
Old 01-24-07, 09:56 PM
blb blb is offline
Casino Cash: $331
Actually, I've had pretty good service out of Camaros with the 350 and Bonnevilles and Park Avenues with the 3800. Generally speaking, there was more room to work under the hood with the 350's and 3800's vs. the Northstar Caddy's. And the low end torque on both the LT1 350 and 3800 are great. True, there is the occasional alternator or water pump to replace, and in the case of the 3800's, the plastic intake manifolds tend to warp and leak coolant into the cylinder, but I never had near the multitude of problems with the Chevy's, Buicks or Pontiacs than I did with the Caddy. Keeping the Caddy on the road sometimes is like a second job....and until I see several of the latest model years in succession where the headgasket issues seem to have been resolved, I will not purchase another one. I think it's great that you are taking the time to learn from people that have owned these cars, so whatever you decide, you will be well informed. Good luck with whatever you decide.
  #36 (permalink)
Old 01-24-07, 10:01 PM
Casino Cash: $13427
Thanks, I've heard all of the above concerning the 350 and 3800. There are two other american engines that I'm looking at..the L67 S/C 3800 in a Park Avenue Ultra, Riv or GTP and the LT1 350 in a Fleetwood Brougham The L67 Supercharged 3800 doesn't have the intake manifold problem the N/A L36's do because the supercharged ones have an aluminium intake manifold. And the LT1 is pretty much bullet proof, except for an issue with exhaust manifold bolts.
  #37 (permalink)
Old 01-26-07, 12:16 PM
Dooman's Avatar
Dooman Dooman is offline
Cadillac Owners Enthusiast
Cadillac(s): 1999 Black and Tan STS
View Dooman's Photo Album
Casino Cash: $310
Check out the Black one in the Classifieds.. Benjamon Simon.. Right price range
  #38 (permalink)
Old 01-26-07, 07:47 PM
chuckdobbins's Avatar
chuckdobbins chuckdobbins is offline
Cadillac(s): 97 deville
View chuckdobbins's Photo Album
Casino Cash: $250
chad ive had my 97 deville for about a year and a half. bought it with 117 and its got 135 now.
i absolutely love this car.
best part...it was dirt cheap.
age dont mean a thing my friend.
test drive, test drive, and test drive...then buy....and enjoy.
ps: you can get a good one for less than 7k
  #39 (permalink)
Old 01-28-07, 08:17 PM
Casino Cash: $13427
I want something newer than 2000, or I'd really prefer it that way. Also, I want something with less than 100k miles, but more like 60-70k, and the only 2000+ Northstar Cadillac I like is the Eldorado, it's very hard to find one that meet those criteria, with the options and colors I like, for less than $10,000.
I've been searching around here a lot lately, and on autotrader.com I found a number of Eldorados from 93-02. 14 matches were found, one met my criteria for years, price and mileage. It was a white '01 ESC for $9,900 with 84k miles and it looks mint, otherwise everything else was too old, too high of miles or too much money. These Eldorados are quite expensive too, some of them are still going for 12-16k!
  #40 (permalink)
Old 01-29-07, 09:25 AM
TripleblackETC TripleblackETC is offline
Cadillac(s): '95 Eldorado black on black
View TripleblackETC's Photo Album
Casino Cash: $275
Just curious, but any particular reason why you want a 2000 or newer N*?
You could probably find a MINT 1993-1995 with really low miles for the kind of money you're willing to spend.
Tags: , , , , , ,
cadillac, honestly, northstar, purchase, wise, year
Cadillac Automotive Concepts
bud davis cadillac
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights | air suspension kits | air suspension parts | air ride suspension
