Go Back   Cadillac Owners Group > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Am I screwed ?
Old 01-16-07, 08:37 PM
smooththg6969's Avatar
smooththg6969 smooththg6969 is offline
Cadillac(s): 99 Seville SLS
View smooththg6969's Photo Album
Casino Cash: $1090
Am I screwed ?
well I was getting excited because My northstar is was going together quite well. I'm trying to put it back in this weekend, but when I went to put the timing cover back on I noticed it was different than the original. the original has the bottom edge cut off for what seems to be a mounting hole for the right engine mount. but the replacement block doesn't have this.
here is a pic of the replacement block cover
you can see the bottom edge is rounded at the corner. now here is a pic with me holding the original timing cover in front of the the replacement.
now do you see what i mean?
heres the mount that supposed to go there from the fsm
there are three other bolts that hold the mount in place I think I can put it on there with a little massaging of the timing cover but I'm thinking about the stress that would be put on the other bolts. I know the side mounts have the least amount of stress put on them But I don't know if I should trust this solution or not. any suggestions?
  #2 (permalink)
Old 01-16-07, 09:32 PM
Cad tech's Avatar
Cad tech Cad tech is offline
Cadillac(s): 03 STS, 97 STS, 58 Eldo
View Cad tech's Photo Album
Casino Cash: $250
Re: Am I screwed ?
so You go a older block...looks like you into some customizing now...you should be alright with the other 3 bolts going in...not alot of pressure there mostly the pressure is on frt and rear mounts...what they did is try to center the engine more to get a smoother ride and shifting like the Aurora..i have a buddy that blew one in his 00 and we stuck a 97 block in it (after we boosted it up) same problem you have...used the 3 bolts then modified a 3.8 top mount to ease even more pressure on it....so not a problem ever with his and he drives it hard...
Tags:
screwed
Cadillac Automotive Concepts
bud davis cadillac
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights | air suspension kits | air suspension parts | air ride suspension
