| Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.). | Cadillac Forums: Oil Level Sensor?
01-10-07, 04:27 PM
| | Cadillac Owners Fanatic Cadillac(s): 96 STS | | Join Date: Dec 2006 Location: Massachusetts
Casino Cash: $385
| | | Oil Level Sensor? The check engine oil level display keeps occuring when I start my car. I know for a factthat the oil level is just fine and it will even do this on a level surface.(In the owners manual, a possible solution says the car may not be on even surface) Is the only solution to this problem to replace it or is there something else? |
01-10-07, 04:31 PM
|  | One rare STS Cadillac(s): 1989 STS / 1993 Brougham / 2001 DTS | | Join Date: Apr 2005 Location: Out In Front
Casino Cash: $7700
| | | Re: Oil Level Sensor? On a 96 it's probably the sensor. If they're anything like the ones I've done there's a small piece that breaks off of them. The part is cheap and it takes about 10 minutes to change.
__________________ Ownership:
89 STS (1 of 1893)
93 Brougham 01 DTS: Custom installed Volant CAI Custom PCM Body color engine components Cruiser Alloy wheels EBC brakes Eibach springs Sportwing Spoiler Semi-custom interior Custom quad Hi-Beams Future Plans: Corsa exhaust, More interior work, Hi-stall converter. Memberships: National and regional Cadillac & LaSalle Club Proud Volunteer - Northstar Tuning Project ---------------------------- |
01-10-07, 04:41 PM
|  | Cadillac Owners Fanatic Cadillac(s): 03 STS, 97 STS, 58 Eldo | | Join Date: Jan 2007
Casino Cash: $250
| | | Re: Oil Level Sensor? Codewise is absolutly correct replace oil level sending unit. The oil level switch is a magnetic reed float style switch which is closed with oil level full and open when oil level is low. The PCM monitors the oil level switch to determine if the oil is LOW or OK. When the Test Conditions have been met the PCM will monitor the oil level switch input. If a low oil level is indicated the PCM will send a serial data message to the Driver Information Center (DIC) or IPC depending upon vehicle model. The DIC/IPC will then indicate the oil level is low. If the Test Conditions have not been met then the PCM ignores the oil level switch input and oil level OK is indicated to the DIC/IPC. The engine coolant temperature Test Condition is required to ensure enough time has passed since the engine was last stopped. The time period/coolant temperature difference is to allow enough time for the engine oil to drain back into the oil pan. The colder the current engine temperature is, the larger the drop in temperature necessary. This is to ensure colder, thicker oil has drained back into the oil pan..........The oil level sending unit is located left of the oil filter, be prepared to drain all the oil out (8 quarts) light tan plastic or brass colored on older models.... |
01-10-07, 04:50 PM
|  | Mercedes Benz Technician Cadillac(s): Calypso Green 1995 Eldorado / 2007 Harley FXDC | | Join Date: Mar 2006 Location: Clearwater Beach, Florida Age: 45
Casino Cash: $875
| | | Re: Oil Level Sensor? Quote:
Originally Posted by Cad tech be prepared to drain all the oil out (8 quarts) light tan plastic or brass colored on older models.... |
Not to nit-pic, but wouldn't that be 7.5 qts?
None the less, welcome to the forum Cad tech.  |
01-10-07, 05:13 PM
Casino Cash: $250
| | | Re: Oil Level Sensor? True but the accepted rate of oil consumption for engines used in the vehicles referenced is 0.946 liter (1 qt) in 3200 km (2000 mi). This rate only applies to personal use vehicles, under warranty, maintained in accordance with the appropriate maintenance schedule, with less than 58,000 km (36,000 mi), or 80,450 km (50,000 mi) for Cadillac, driven at legal speeds in an unloaded (for trucks) condition. So why not start out .5 quart ahead  most dealerships, plus the one I work at, use 8 quarts, it is standard through the industry for the high oil consumption rate
and 10 quarts after lower crankcase seals......
thanks for the Welcome |
01-10-07, 05:41 PM
Casino Cash: $385
| | | Re: Oil Level Sensor? How much are they to replace? Could I get one at an Auto Zone or something? |
01-10-07, 06:20 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 60
Casino Cash: $15011
| | | Re: Oil Level Sensor? I doubt AZ would have them. Probably will have better luck (and price) at http://www.gmotors.com
Cad Tech, just realized you were new.  Always nice to have another tech around.
I do just the opposite. I use 7 qts. Easier to measure plus we heard from our old Guru that 8 qts was overfilled and would exacerbate oil consumption. |
01-10-07, 06:31 PM
Casino Cash: $7700
| | | Re: Oil Level Sensor? I wouldn't ever overfill the oil. You safer being a half qt down than you are over full.
Why 10 qrts after a halfcase gasket? |
01-10-07, 07:40 PM
Casino Cash: $15011
| | | Re: Oil Level Sensor? He may be talking about the 8 qt overfill (16 qts) procedure to reprime the oil pump, like when the check valve sticks open. |
01-10-07, 08:05 PM
Casino Cash: $250
| | | Re: Oil Level Sensor? Sorry for starting such a cotraversy over oil capacity lmao.....
required is 7.5 quarts but like I said before the norm is 8 quarts and after working on cadillacs for over 15 years and on the 4.6L that is norm. remember that oil burn as I pointed out above. Concerning the lower crankcase seals, yes 10 quarts after doing this repair..If you have ever had one apart you would see that the oil manifold keeps in alot, standard for that is 10 quarts and after doing over 200 in just 2006 (they keep track of that crap at dealerships due to auditing) never had one problem last year or since 1993. Also consider oil cooler please..
Also if you remove the oil pan on the 4.6L it holds to the tippy top 12 quarts of oil.... so the risk of hurting anything is none by adding the extra .5 quart | | Cadillac Discussion Tools | | |
Censor is ON | | | |
