Go Back   Cadillac Owners Group > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Seville Engine replacement.
Old 01-06-07, 10:50 AM
tp001 tp001 is offline
Cadillac(s): Cadillac
View tp001's Photo Album
Casino Cash: $275
Hi every body. I need some advice from you guys.
I got a Seville STS with a cracked block. I try to replace the engine but I can,t find any L37 locally. There a junk yard has a LD8 with blowed HG. Can I use that engine to replace my engine with my cyclinder heads. Is there same as the L37?
Thank
  #2 (permalink)
Old 01-06-07, 11:00 AM
CadillacSTS2003's Avatar
CadillacSTS2003 CadillacSTS2003 is offline
AKA CadillacETC1997
Cadillac(s): 03 STS, 97 ETC, 98 STS, 05 STS, 06 STS-V, 74 Eldo Vert
View CadillacSTS2003's Photo Album
Casino Cash: $6555
Re: Seville Engine replacement.
no
different pistons and cams were on the L37
  #3 (permalink)
Old 01-06-07, 11:17 AM
Casino Cash: $275
Thanks CadillacECT.
You saying is the block are difference too?
I read that the difference are the intake cam and the gear only.
  #4 (permalink)
Old 01-06-07, 12:00 PM
zonie77 zonie77 is offline
Cadillac(s): 94 ETC
View zonie77's Photo Album
Casino Cash: $5129
What years?
Why do you think you have a cracked block? Can you see the crack? Where is it?
  #5 (permalink)
Old 01-06-07, 12:03 PM
JimD JimD is offline
Cadillac(s): '98 STS
View JimD's Photo Album
Casino Cash: $9433
Thank
Yes. Be sure to use your L37 heads and cams; the intake valve lift and duration is the difference as far as the engine is concerned.
And of course, Time-Sert the bolt holes in the block.
  #6 (permalink)
Old 01-06-07, 07:16 PM
Casino Cash: $275
My car is 96 serville STS L37, the other LD8 is 98. one of the piston is broken and broke the block . I just want it run OK and smooth . not mind about the power little less.
  #7 (permalink)
Old 01-06-07, 08:03 PM
mtflight's Avatar
mtflight mtflight is offline
Cadillac(s): 2003 White Diamond DHS
View mtflight's Photo Album
Casino Cash: $1855
Definitely get an L37 unless you want a real headache. The computer and transmission are programmed for the L37 you have. You'd likely spend a lot of time and frustration trying to make it work right without faults and gremlins if you try the LD8 (unless you swap everything including the transaxle and the computer).
Regarding a replacement engine. I would recommend a remanufactured engine with a warranty. That's what I'd get if it was me in your spot.
Here's a link to a 3 yr / unlimited mile warrantied Northstar, that has been TimeSerted (very important procedure so that you don't get pulled headbolts and headgasket troubles).
http://cgi.ebay.com/ebaymotors/93-99...QQcmdZViewItem
Good luck. Let us know what you end up doing.
  #8 (permalink)
Old 01-07-07, 03:24 AM
Cadillac(s): 94 ETC
Casino Cash: $5129
Several months ago someone posted changing to a 275 hp from a 300. They were happy but had only driven it a short while. I havn't caught another post and I asked them for more details but no answer.
The shift points are different. If you are doing city driving you are probably going to be happy. If you are doing more high speed/freeway driving maybe not so happy. The 275 has a lower torue and HP curve so higher rpm shifting is not as compatible. It will run and may be satisfactory but it will depend on your expectations. Swapping the 275hp for the 300 works a lot better than the other way around.
If you make this change let us know how it works.
  #9 (permalink)
Old 01-07-07, 03:26 AM
Cadillac(s): 94 ETC
Casino Cash: $5129
If you buy the engine with the bad HG's maks sure you repair them by timeserting the block.
timesert.com
Tags: , ,
engine, replacement, seville
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights
