Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: 96 SLS Head Gasket
Old 12-07-06, 03:21 PM
Cadillac(s): Cadillac
View cadguy's Photo Album
Casino Cash: $250
96 SLS Head Gasket
Has anyone done a head gasket on a 96 SLS with the Northstar Engine. How difficult is it for the DIY person with some automotive experience
any help would be appreciated
Ron
  #2 (permalink)
Old 12-07-06, 04:21 PM
Cadillac(s): 1997 Seville SLS
View boricuacaddy's Photo Album
Casino Cash: $2878
Re: 96 SLS Head Gasket
Hi. I guess you have run into the dreaded HG disease! Here is a link that has some great information with steps to get you started. There is also another link in there that shows some PICS. Hope it helps.
David
http://www.cadillacforums.com/forums...et-repair.html (N* Head Gasket repair)
  #3 (permalink)
Old 12-07-06, 09:04 PM
dp102288's Avatar
Cadillac(s): 1995 Pearl White Diamond Cadillac Eldorado ESC
View dp102288's Photo Album
Casino Cash: $250
cadguy, you sure its the head gaskets right?
  #4 (permalink)
Old 12-08-06, 10:45 AM
Cadillac(s): 94 ETC,97 STS
View zonie77's Photo Album
Casino Cash: $7854
The HG's on a Caddy aren't that bad but the easiest way it to drop the cradle. The good thing is you don't have to lean over the fender for the whole job. Once the cradle is out it's pretty easy to do the rest.
The second difference is you should timesert ALL 20 bolt holes, even if they don't look bad...it is the safe thing to do.
  #5 (permalink)
Old 12-09-06, 08:49 AM
Casino Cash: $250
Thanks for the responses, I hope to start the within a few days. I do a few more questions based upon your responses. Yes, I sure the head gasket is bad and it is the rear head. Why would I need to drop the cradle, Can I not disconnect the top mounts and roll the engine forward a little to access the rear earier. What is a timesert?
Thanks Ron
  #6 (permalink)
Old 12-09-06, 04:38 PM
View Ranger's Photo Album
Casino Cash: $24266
http://www.timesert.com
  #7 (permalink)
Old 12-09-06, 07:18 PM
Casino Cash: $7854
It has been done that way but it is the hard way to do it. The total amount of work and the total time will probably be substantially more than if you dropped the cradle.
  #8 (permalink)
Old 12-09-06, 07:51 PM
Casino Cash: $7854
The engine was designed to be removed to do the HG's. Many things are hard to access in the car. You will waste more time than dropping the cradle.
Are you planning to timesert the block? It is very difficult to do that with the engine in the car. If you have bad HG's you probably have bad threads in the block on at least one hole.
I think you should reconsider trying to do it in the car.
  #9 (permalink)
Old 12-09-06, 10:33 PM
dp102288's Avatar
Casino Cash: $250
I also say drop the engine. I read a while ago that it is near impossible to do even a half-assed job if you don't.
Why not now, or else then again later?
  #10 (permalink)
Old 12-10-06, 08:05 AM
Casino Cash: $250
Thanks for the info on the timesert.
Do you have to take the engine out from the top or the bottom? If it is the bottom, would I have enough clearnace to actually get it out with the car on jack stands?
Thanks
RON
  #11 (permalink)
Old 12-10-06, 11:31 AM
Casino Cash: $7854
Did you read the thread that boricuacaddy posted?
You can pull the engine out the top but it's harder that way too. There are some bolts that are very difficult to access and you have to seperate it from the trans.
As scary as it seems it's actually pretty easy to pull the cradle.
Read that post and get a factory service manual (FSM).
Tags: , ,
gasket, head, sls
