Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Engine miss
    jholland is offline Cadillac Owners Member
    Automobile(s): '97 Seville '76 Eldorado
    Apr 2005
    67
    Engine miss
    I have just done a HG on my N*. Everything seems to be OK. The engine was out of balance, but I wouldn't call it missing when I first started driving it. Each time I drive it it seems to get better. The milage is 23.5. I put in new plugs. I looked at the front bank and if anything they are burning a little lean. I will ocassionally stumble at idle and when it is lugging on a hill. The tac will also occasionally jump around but there is no noticeable affect on the engine when the tac is irratic. Before the HG job the coil paks seemed to be making a clattering noise, that is gone now, the only differnce on the ignition side is new AC plugs. I'm sure the next logical move is plug wires and coil paks. Any advice on the how to diagnose this further.
    69
    82,273
    Re: Engine miss
    Mist the wires in a dark place at night and look for a light show. I'd suspect the wires before coils, especially if they are original and the fuel rail recall has been done. Seems to be a common problem afterwards.
    GreenMachine's Avatar
    GreenMachine is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Deville
    Jun 2005
    Amherst (Buffalo), New York
    29
    484
    Re: Engine miss
    Also if you have a Multimeter you can check the wires for proper resistance, I believe its 15K OHms or similar.
  5. #4
    Apr 2005
    67
    Re: Engine miss
    The fuel rail was recently done. I had the codes read last night. Current codes are P0441,P1370,P1375 and P1376.
    P0441 - Evaporative Emission Control System Incorrect Purge Flow
    P1350 - Ignition Control System
    P1375 - IC 24X Reference Circuit High Voltage
    P1376 - Ignition Ground Circuit
  6. #5
    Apr 2005
    67
    Re: Engine miss
    I sprayed the plug wires at night and didn't get a lightshow. I replaced the plug wires anyway. It runs better but far from correct. Is there any way to test the coils?
  7. #6
    69
    82,273
    Re: Engine miss
    Listen for arcing with a stethescope, pull then and look at the contacts for signs of arcing or what I think is the best way, swap them out one at a time with a known good one from another car.
  8. #7
    Apr 2005
    67
    Re: Engine miss
    Thanks, I will have a car available tomorrow.
  9. #8
    clarkz71's Avatar
    clarkz71 is offline Cadillac Owners Connoisseur
    Automobile(s): 2000 Eldorado ESC
    Mar 2006
    Fort Lauderdale, Florida
    53
    1,361
    Re: Engine miss
    Quote Originally Posted by jholland View Post
    Did you re-install the ground cable that goes from the head to the coil/module bracket?
  10. #9
    Apr 2005
    67
    Re: Engine miss
    Yes. Asside from the engine misfiring badly the tach was randomly jumping around. I added a 12 ga. wire from the ignition module to the strut tower and the erratic tach completely went away. I can't get the engine to body ground wire off to clean it. The stud is too rusted. I'm soaking it for a while rather than risk breaking it. The clattering sound I refered to in the earlier post was the PCV valve. Just replaced it and the split rubber boot connected to it. I can here noise in the coil area. When the engine is cold or running at highway speed the engine is almost smooth, under load there isn't much power. I just ordered a complete used ignition module with coils. It is supposed to be off a wrecked 95 car. For 50 bucks its worth a shot.
  11. #10
    Apr 2005
    67
    Re: Engine miss
    Installed the ignition module and the engine miss is gone. The coils that came of the car don't appear to be OEM.
  12. #11
    clarkz71's Avatar
    Mar 2006
    53
    1,361
    Re: Engine miss
    Glad you got it fixed.
  13. #12
    Apr 2006
    North Brunswick, NJ
    28
    4,236
    Re: Engine miss
    Congrats.
  14. #13
    tccadieldo is offline Cadillac Owners Member
    Automobile(s): 99 eldorado
    Mar 2010
    14
    Re: Engine miss
    Another trick that I think it was Ranger taught me, is to just trade your existing coil packs around and check for spark loss and it will tell you what coil pack is bad. The one that is bad will be the one that has no spark no mattter where you install it. Another thing, you can see if the contact area is dry of grease between the mounting plates.
  15. #14
    bjmobile is offline Cadillac Owners Member
    Automobile(s): 1997 STS
    Jan 2011
    13
    Re: Engine miss
    informative. thread bookmarked.
  16. #15
    97EldoCoupe's Avatar
    97EldoCoupe is offline Owner of Northstar Performance
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    The Great White North
    31
    2,600
    Re: Engine miss
    People are paying $50 for used ICM's and coil packs? Wow I'll have to sell my collection soon
  • You may not post replies
