Go Back   Cadillac Owners Group > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Northstar Misfire... no error codes
Old 11-02-06, 10:03 PM
akimball442's Avatar
akimball442 akimball442 is offline
Cadillac(s): 98 Seville SLS, 81 CDV, 84 Olds 98 Coupe, 78 M-Benz 300CD
View akimball442's Photo Album
Casino Cash: $485
Question Northstar Misfire... no error codes
1998 Seville SLS
I was on the NYS thruway today, and as I began climbing a hill, I noticed the engine beginning to miss like crazy. I've never had a 96 or newer vehicle that didnt start flashing the check engine light during this condition. So once I got done with the hills, I punched it a few times, and sure enough, under load it misses like crazy... for the most part. Sometimes it's ok. What would suddenly cause this? Cruising and normal driving are fine. Gas mileage is fine, car is otherwise in good condition.
64000 miles
Any ideas?
Aaron K
  #2 (permalink)
Old 11-02-06, 10:36 PM
Ranger Ranger is online now
View Ranger's Photo Album
Casino Cash: $15011
Re: Northstar Misfire... no error codes
Plug wires. Stick with A/C Delco.
  #3 (permalink)
Old 11-04-06, 11:47 AM
Casino Cash: $485
Wow, the AC ones are sure expensive... oh well, guess that's the price you pay for driving a cadillac. I just wish this car wasnt constantly nickel and diming me to death.
  #4 (permalink)
Old 11-04-06, 12:27 PM
dkozloski dkozloski is online now
Cold Soaked
Cadillac(s): 2006 STS AWD, '95 Ford Ranger
View dkozloski's Photo Album
Casino Cash: $11817
What do you mean by nickel and diming? It's dollaring isn't it?
  #5 (permalink)
Old 11-04-06, 01:38 PM
thu's Avatar
thu thu is offline
Cadillac(s): 2003 STS, 1993 Deville, 1985 Deville
View thu's Photo Album
Casino Cash: $2190
Are you sure it's missing? Perhaps the engine is starving for fuel? From your symptoms, it happens only when you want more power but is fine otherwise. This is typical of a plugged filter or malfunctioning fuel pump.
  #6 (permalink)
Old 11-04-06, 03:17 PM
Cold Soaked
Casino Cash: $11817
Opening the throttle increases cylinder pressures which increases the voltage required to jump the gap of the sparkplugs. The same increase causes the spark to jump to ground through flaws in the plug wire insulation or some place in the ignition. I'd look under the hood with the car in as dark a place as I could find and the engine running. Spray water on the plug wires with a spray bottle. If the wires are bad you'll know right away.
  #7 (permalink)
Old 11-04-06, 04:54 PM
Casino Cash: $15011
  #8 (permalink)
Old 11-04-06, 10:29 PM
joe_padavano joe_padavano is offline
Cadillac(s): 93 Allante
View joe_padavano's Photo Album
Casino Cash: $307
I had exactly the same problem on my 93, and it got steadily worse. Since the car had 80K+ miles, I replaced plugs and wires first, but that did not fix the problem. I replaced the ignition module and coils next, and the car has never run better. Be sure to get an AC Delco ignition module (though be prepared for a $350+ price tag). I used MSD coils instead of Delco because they were both less expensive and higher voltage (though they are bright red).
Tags: , , ,
codes, error, misfire, northstar
Cadillac Automotive Concepts
bud davis cadillac
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights | air suspension kits | air suspension parts | air ride suspension
