| Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.). | Cadillac Forums: P0533... fuel gauge is going nuts
10-24-06, 11:05 PM
| | Cadillac Owners Member Cadillac(s): 1997 Seville SLS | | Join Date: Mar 2005 Location: Detroit, MI Age: 33
Casino Cash: $295
| | | P0533... fuel gauge is going nuts I looked up this code and saw that is "FUEL SENSOR OPEN/SHORTED TO B+". Can anybody translate this and tell me what I need to do to remedy this and what I might expect it to cost me? |
10-24-06, 11:52 PM
| | Cadillac Owners Fanatic Cadillac(s): 97 Seville STS, black on black | | Join Date: Nov 2004 Location: MA Age: 22
Casino Cash: $275
| | | Re: P0533... fuel gauge is going nuts This means your sensor in the tank has bit it. The wonderful thing is that the sensor is incorporated into the pump and everything else, so it has to be replaced as a unit, which means dropping the tank. I'm looking at it pretty soon myself, cause my pump is starting to whine, and I was told about 500-600 bucks.
Depending on the year of your car the tank has to be dropped or can by accessed through a panel under the rear seat. I believe 98+ has the panel, 97 and below you need to drop the tank. |
10-25-06, 12:35 AM
| | Cadillac Owners Connoisseur Cadillac(s): 94 ETC | | Join Date: Sep 2003 Location: Arizona
Casino Cash: $5554
| | | Re: P0533... fuel gauge is going nuts You might try fuel injector cleaner. Some gas additives will cause problems with the sensor. Use it per the instructions, do not use it stronger than recommended.
If it works it's a lot cheaper than the sensor. |
10-25-06, 01:10 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 40
Casino Cash: $10262
| | | Re: P0533... fuel gauge is going nuts Probably needs a "fuel level sensor kit".
It is serviceable separately from the pump module for almost any car I can remember with a modular pump.
It would be nice to know what kind of car we are talking about, like year and model.
Getting to the sensor does vary based on the model and year.
Some you have to remove the tank, some have an access panel in the trunk. |
10-25-06, 03:40 PM
Casino Cash: $295
| | | Re: P0533... fuel gauge is going nuts Quote:
IT'S A '97 SLS... |
10-25-06, 06:56 PM
Casino Cash: $10262
| | | Re: P0533... fuel gauge is going nuts The tank needs to be drained and taken out.
You'd have to call to be sure, maybe look online, I think GM list price for the sensor kit is $175 or so.
I am sure the teeth are worn off the sensor.
I see a lot of them.
I posted pictures of a worn out one somewhere a while back. |
10-26-06, 02:39 PM
Casino Cash: $295
| | | Re: P0533... fuel gauge is going nuts Thanks for the info. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
