Originally Posted by chevelle The belt grooves should have very little to no runout. If they have discernable runout then I would consider replacing the damper. |
Cripes. I
was looking at the belt grooves.
Well, at least it's only a $30 part. Rock auto says: DORMAN Part # 594195 - $30.79.
I'll do a search on replacing it. Thanks guys
edit - looks straightforward. Bolt is lubed with oil, tightened to 44ft-lb, then an additional 120 degrees. Does autozone rent the puller and installer? Just the "standard" harmonic balancer puller, right?
