Originally Posted by ELDOminator How much did the new pump run ya? And is that a Stealership kinda job? |
Dominator, for my 94 Seville, at O'Reilly's the fuel filter was $12 and the pump was $85. Installation about 2.5 hours.
If you can change your own spark plugs, clean a throttle-body and hold 25 pounds over your head for five minutes, then you can probably fight your way through replacing a fuel pump. Here are a few notes;
- Drive until the tank is as empty as you are comfortable driving it with
- You'll have to remove the shielding between the exhaust and the floor
- Removing the filler hose from the funnel to the tank is a son-of-a-gun
- Do work in a
well ventilated area
Good luck
