Go Back   Cadillac Owners Group > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Anyone have HG pics? Not overheating but probs...
Old 10-07-06, 09:32 PM
85Y 85Y is offline
Cadillac(s): 1997 Deville
View 85Y's Photo Album
Casino Cash: $250
First off I just find it weird that I can't find any pictures of failed headgaskets. I usually take pics of my R&R but maybe that's just me. I was hoping that some pictures of the failed headgaskets would help me narrow down my problem a bit more.
Coolant leaks: Found the upper heater hose on my '97 Deville leaking through the factory rivet hole. Fixed that and then a leak sprung at the radiator endtank. Fixed that and flushed the coolant which was murky brown (DOH!). Also added bars leaks tablets. I had only owned the car for about 2 months at that time. A third leak developed at one of the short hoses near the backside of the throttle body. I tightened up that hoseclamp and wish I wouldn't have Looks like now that my cooling system is all sealed up, I uncovered a bigger problem.
I filled the purge tank up to just below the filler neck and went for a drive...I have my AC accumulator out and routed the overflow tube into a 2-liter bottle. I had about 32 oz of dexcool in it on a 25 minute trip...no overheating but it started misfiring on a cylinder or 2. I later read in the owners manual to fill 2.5" below the fillerneck so I did and still had the misfire. Pulled the plugs and all the groundstraps were white--none looked steamcleaned.
Drove to the autopart store and got a block test kit where the fluid is supposed to turn from a blue to a yellow color if ehaust gas is in the
coolant. It was dark out. I ran the car for a minute to test it and then went in my glovebox to get my flashlight to check the color of the test fluid. In those 15 seconds, I went back underhood and I had boiled out about 2 quarts of coolant.
So...I've never overheated but it looks like it might be headgasket time. Just some things I was thinking of. I had replaced my positive battery cable and the intake manifold bolts were all loose. Since it appears to be a 'dry' manifold, I am assuming that all the plugs being white were not from an intake leak. All of those bolts being loose though makes me wonder about the headbolts actually loosening up which might be more common than a headgasket failure in my mind because I haven't seen pictures of bad headgaskets. I was going to use an air-hold in the sparkplug hole but the autopart store open late didn't have one tonight. I figure that I could narrow it down a bit more by using an airhold since I no longer have my leakdown tester.
I was also wondering about the timeserts. I read that the later N*s used a coarser thread for the headbolt. If this is true, do they make the threadsert kit in that size and would I be better off buying that kit and later headbolts or is the OD/threads on the timesert the same (if they have one available) for both models?
I'm going to pull the injector clips off a bank of cylinders at a time and run the block test again during the daytime...hopefully that will be able to enlighten me some more and narrow down the problem.
Thoughts?
  #2 (permalink)
Old 10-08-06, 12:10 AM
Ranger Ranger is online now
View Ranger's Photo Album
Casino Cash: $15011
Re: Anyone have HG pics? Not overheating but probs...
First off, the murky brown coolant is from the sealant tabs. Perfectly normal. Sounds like you never got to run the hydrocarbon test. Do you see bubbles in the surge tank when you start it? Before you condem the head gaskets, check the cheap easy things first, like the thermostat and be sure that the purge line is clear and free flowing. Overfilling the surge tank will surely cause it to overflow. The cylinder pressure test will tell the tale for sure.
  #3 (permalink)
Old 10-08-06, 12:27 AM
white97deville white97deville is offline
Cadillac(s): '97 Deville
View white97deville's Photo Album
Casino Cash: $275
There is a pic of a bad headgasket in the link below. I would test a little more and be positive of a bad hg before ripping into it.
http://www.cadillacforums.com/forums...ir-part-i.html (N* Head Gasket repair part I/ Remove engine)
  #4 (permalink)
Old 10-08-06, 12:41 AM
zonie77 zonie77 is offline
Cadillac(s): 94 ETC
View zonie77's Photo Album
Casino Cash: $5554
The symptoms sound like a HG leak but the byproduct test or cyl pressure test would confirm it.
The HG leak allows combustion pressure into the cooling system forcing out coolant. The engine is not necessarily overheating.
Ust the correct timeserts and don't worry about a thread change. With the steel timesert you have plenty of strength.
  #5 (permalink)
Old 10-08-06, 12:42 AM
Cadillac(s): 94 ETC
Casino Cash: $5554
I think Harry Yarnell posted pics of a blown gasket. There have been a few posted but if you've seen one...
  #6 (permalink)
Old 10-08-06, 12:45 AM
85Y 85Y is offline
Casino Cash: $250
Thanks for the advice fellas! It would be great if it ended up being a bad fuel pump even though I just put one in about 3000 miles ago.
Ranger: I have read posts where you mentioned to do that test with the purge line. I'll admit to all that I got the idea of headgaskets ingrained in my skull. I haven't done that yet but found the post where you went in depth where someone apparently had the blockage way down the line. I'll do that first thing in the morning.
White97--Thanks for the link! You are apparently better at the search function than me!
I was able to do the hydrocarbon test but it was inconclusive. At night the color of the fluid could have been either a blue-green OR a yellow so when I went to get my flashlight that is when I boiled over a bunch. I *should* have enough test fluid to do 3 more tests...a normal one during the daytime and a split test with fuel injectors from each bank disconnected.
I do know this much before tomorrow...when I popped the hood earlier today when I had overfilled the purge tank (because I didn't RTFM), there was pressure in my rigged 2-liter bottle. I have not seen any movement of fluid though during a fresh and cold startup which I am hoping means that the purge line isn't working correctly. I would expect some movement on the fluid in the overflow tank if the purgeline is supposed to be supplying it with a constant supply of DexCool.
I can't complain...a 97 DeElegance with 104k when I got it for $2500. So far a new fuel pump, blower motor, and positive battery cable with a clean carfax. If I do have to pull (er, drop) the engine, I will be able to fix the rear main seal too which drips oil right onto the Ypipe and through my vents when I have it on ECON. I'll keep everyone updated even if I overlooked something simple!
  #7 (permalink)
Old 10-08-06, 12:50 AM
85Y 85Y is offline
Casino Cash: $250
Zonie-Didn't catch your reply in time--yeah, I know it seems pretty obvious what a blown headgasket looks like but I am from the cam-in-block engines where you'll usually fill your crankcase up with oil. I suppose the N* is the first engine I have dealt with (I am sure other engines are out there) that milkshake in the oilpan does not happen with a blown gasket.
  #8 (permalink)
Old 10-08-06, 01:12 AM
Casino Cash: $15011
"I'll admit to all that I got the idea of headgaskets ingrained in my skull."
We all do. Bad case of internetforumitis. When my '97 got a hairline crack in the surge tank and coolant leaked so slow that I never saw it til I got the CHECK COOLANT LEVEL message, I damn near had a coronary. Was sure it had to be head gaskets. Turned out to be just a crack at the purge line nipple and I was able to repair it with JB Weld.
  #9 (permalink)
Old 10-08-06, 01:41 AM
Casino Cash: $275
The oil leak may not be coming from your rear main seal either. When I had my engine out there were no oil leaks at all except from the headgasket area. Car had 123,000 miles on it at the time. Half case seals and oil pan gaskets are usually the problem areas. Good luck with your Nstar.
  #10 (permalink)
Old 10-08-06, 03:40 AM
Cadillac(s): 94 ETC
Casino Cash: $5554
I've seen plenty of engines that had blown HG's that did not put oil in the coolant. It depends where it blows. Between two cyls is very common on older engines and no coolant in the oil. That coolant in always in the oil is BS, it's only one possible symptom.
On older cars blown HG's were incorrectly diagnosed as bad valves a lot.
Tags: , , ,
overheating, pics, probs
Cadillac Automotive Concepts
bud davis cadillac
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights | air suspension kits | air suspension parts | air ride suspension
