| Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.). | Cadillac Forums: 2 N* Questions - Coolent and Tranny Dipstick?
10-06-06, 01:02 PM
| | Cadillac Owners Enthusiast | | Join Date: Jul 2005
Casino Cash: $250
| | | Re: 2 N* Questions - Coolent and Tranny Dipstick? The BarsLeak "golden seal" powder is the same stuff, yes. And BarsLeaks also markets the sealant in the same pellet form as the GM coolant supplement.
Just be sure to put the sealant directly in the radiator hose. Do not be tempted to just dump it into the surge tank. |
10-06-06, 02:33 PM
| | Cadillac Owners Fanatic Cadillac(s): 99 Deville Concours | | Join Date: Jul 2006 Location: Tuscaloosa, Al. Age: 52
Casino Cash: $440
| | | Re: 2 N* Questions - Coolent and Tranny Dipstick? Quote:
Originally Posted by chevelle The BarsLeak "golden seal" powder is the same stuff, yes. And BarsLeaks also markets the sealant in the same pellet form as the GM coolant supplement.
Got it...  Top hose, engine side......
Thanks..... |
10-07-06, 02:17 PM
|  | Cadillac Owners Member | | Join Date: Oct 2005 Location: Catskill region, NY Age: 60
Casino Cash: $250
| | | Re: 2 N* Questions - Coolent and Tranny Dipstick? I have a 2000 Deville DHS and I was told by the mechanics that there is no dipstick for the tranny since it is a sealed system. The only access to the cooling system is the cap on the overflow tank and there have been problems with cap leaks according to the Cadillac serve bulletins. Loss of coolant is not normal and may be a sign of the problems that many of have had with head gasket leaks. See all the forum entries regarding overheating and head gaskets. Sorry to be the bearer of bad news but it's best to have it checked now before the problem causes constant overheating, loss of coolant and then complete engine shutdowns. |
10-07-06, 02:40 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2002 Seville SLS | | Join Date: Nov 2004 Location: Woodbridge NJ Age: 42
Casino Cash: $3344
Originally Posted by MUGSANDLUKE I have a 2000 Deville DHS and I was told by the mechanics that there is no dipstick for the tranny since it is a sealed system. The only access to the cooling system is the cap on the overflow tank and there have been problems with cap leaks according to the Cadillac serve bulletins. Loss of coolant is not normal and may be a sign of the problems that many of have had with head gasket leaks. See all the forum entries regarding overheating and head gaskets. Sorry to be the bearer of bad news but it's best to have it checked now before the problem causes constant overheating, loss of coolant and then complete engine shutdowns. | Well looky here. I am no Cadillac service specialist, but there seems to be a dip stick for the trany here. Maybe you need to frequent a different service department.
Don
10-07-06, 02:43 PM
Casino Cash: $3344
| | | Re: 2 N* Questions - Coolent and Tranny Dipstick? Here is a better pic.
Don
10-07-06, 03:03 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 60
Casino Cash: $15011
Originally Posted by MUGSANDLUKE I have a 2000 Deville DHS and I was told by the mechanics that there is no dipstick for the tranny since it is a sealed system. The only access to the cooling system is the cap on the overflow tank and there have been problems with cap leaks according to the Cadillac serve bulletins. Loss of coolant is not normal and may be a sign of the problems that many of have had with head gasket leaks. See all the forum entries regarding overheating and head gaskets. Sorry to be the bearer of bad news but it's best to have it checked now before the problem causes constant overheating, loss of coolant and then complete engine shutdowns. | Time to find another mechanic. Perhaps your head gaskets were not bad after all. |
10-07-06, 11:28 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2000 Bronzemist Seville STS | | Join Date: Sep 2004 Location: Tacoma, WA Age: 46
Casino Cash: $705
| | | Re: 2 N* Questions - Coolent and Tranny Dipstick? My wife's 2002 Explorer has a "sealed transmission" and thus no dipstick. Dumbest thing I have ever seen. I realized right away where the dipstick was...behind a desk in Detriot designing Ford transmissions! |
10-07-06, 11:35 PM
| | Cold Soaked Cadillac(s): 2006 STS AWD, '95 Ford Ranger | | Join Date: Jul 2004 Location: Fairbanks, Ak Age: 69
Casino Cash: $11817
| | | Re: 2 N* Questions - Coolent and Tranny Dipstick? The CTS has a sealed transmission and is assembled in a cleanroom. CTS transmission problems are just about unheard of. The idea of reducing the introduction of dirt into the transmission is a good one if the transmission is bulletproof to start with. |
10-08-06, 10:44 AM
| | Cadillac Owners Connoisseur | | Join Date: Feb 2004 Location: FL
Casino Cash: $5065
| | | Re: 2 N* Questions - Coolent and Tranny Dipstick? pray your seals don't leak...
$3000 bill to remove and overhaul transmission because you can't add fluid... |
10-08-06, 11:13 AM
Casino Cash: $11817
Originally Posted by eldorado1 pray your seals don't leak...
$3000 bill to remove and overhaul transmission because you can't add fluid... | You can check and add fluid. You just have to know how and where. I refer you to page 7-379 in the Helm shop manual. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
