Go Back   Cadillac Owners Group > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Oxygen Sensors Grounding
Old 09-24-06, 05:20 PM
rahanna rahanna is offline
Cadillac(s): Cadillac Deville 96
View rahanna's Photo Album
Casino Cash: $250
After AAMCO finished working on my [COLOR=blue! important][COLOR=blue! important]transmission[/color][/color], which took them about 6 weeks ??? ... I got the car and drove it for about 10 miles, then I got the Check Engine Light and the following PCM Errors:
- PCM 0140
- PCM 0141
- PCM 0155
I cleared the PCM codes several times, but after driving for about 10-15 miles, it will come back again at the Computer rebuilds its data ...
I have been reading about the [COLOR=blue! important][COLOR=blue! important]O2 [COLOR=blue! important]Sensors[/color][/color][/color] and figured that it might be a grounding problem ...
Can anyone guide me through the steps of reaching the Ground [G109] for the [COLOR=blue! important][COLOR=blue! important]Oxygen [COLOR=blue! important]Sensors[/color][/color][/color] and whether there might be anything else that I should check ??? ... Some threads indicated that it might be near the Park/Neutral Switch, but I don't know how to reach that spot either (From top or underneath the [COLOR=blue! important][COLOR=blue! important]car[/color][/color]) ...
  #2 (permalink)
Old 09-24-06, 07:00 PM
FrankT's Avatar
FrankT FrankT is offline
Cadillac Owners Enthusiast
Cadillac(s): 99 STS
View FrankT's Photo Album
Casino Cash: $5554
Re: Oxygen Sensors Grounding
RHanna,
I wish I could tell you exactly were G109 is but my best guess would be to look around the coil pack at the rear of engine.
Don't forget to check the fuses, the heater circuits are on a fuse in the engine compartment power distruibtion box.
Frank
  #3 (permalink)
Old 09-24-06, 07:41 PM
chazglenn3's Avatar
chazglenn3 chazglenn3 is offline
Cadillac(s): 2000 Bronzemist Seville STS
View chazglenn3's Photo Album
Casino Cash: $705
I had that exact ground wire broken on my 96 STS when I owned it. It is on the drivers side of the motor just below the rear bank cylinder head. I wasn't able to fix it myself as I couldn't get to it, but the dealer fixed it in less than 1/2 an hour...sure would be nice to own a lift.
  #4 (permalink)
Old 09-25-06, 01:11 AM
Casino Cash: $250
Thank you for the replies ...
I have checked the fuses and they seem to be fine ...
As for the lift, I have one, but I am not sure if it easier to get to that spot from above or below ???
Does anyone have a drawing of the Oxyegn Sensor Grounding location so that I can stick my hand in the right spot ??? ...
Also, is it just a wire that is conencted to the Firewall or to the engine itself ???
Thanks again !!!
  #5 (permalink)
Old 09-25-06, 06:47 PM
FrankT's Avatar
Cadillac(s): 99 STS
Casino Cash: $5554
Thanks again !!!
I don't have a drawing of G109 but the location is: The left hand rear corner of the engine, near the park/neutral position switch.
Its a black wire and usally connected to the frame, engine or coil pack mounting bolt.
I would located the HO2S and follow the harness, there might should be a black wire the harness, trace it. OR disconnect the harness at the H02S connector and ohm the black wire to ground, the reading should be 5.0 ohms or less.
Frank
  #6 (permalink)
Old 09-26-06, 10:18 PM
chazglenn3's Avatar
Casino Cash: $705
On my car, it was a black wire connected to the engine block. When I took it to the dealer and explained what I wanted done, the advisor said "we can fix that pretty quick since we have a lift", so I assume it is easier from below.
Tags: , ,
grounding, oxygen, sensors
Cadillac Automotive Concepts
bud davis cadillac
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights | air suspension kits | air suspension parts | air ride suspension
