Results 1 to 5 of 5
Thread: Oil Question?????
    aamusls06's Avatar
    aamusls06 is offline Cadillac Owners Fanatic
    Automobile(s): 94 Cadillac Seville SLS, 88 Cadillac Deville, Trailblazer SS
    Mar 2006
    Logan, OH
    30
    192
    Oil Question?????
    Ok. I bought my 94 Caddy SLS in april with 113,000 miles and changed the oil at the 114,000 mark. I used Castrol 10W30 high mileage oil. I've had alot of experience with Castrol from having it in a car that was driven over 500,000 miles(Castrol 20W50) and in our John Deere Diesel farm tractors. I also run the 20W50 in a 88 Cadillac 4.5 Deville that seems to be responding well to it. Over 180,000 miles on it.
    Here's the question, I want to switch to a synthetic blend of Mobil Oil. What would be the best weight for a N* with 119,000 miles. I fear running heavy oil in the N*, because I just don't trust it like the older motors I've ran 20W50 in.
    What do you all recommend?
    Elmer Fudd is offline Cadillac Owners Fanatic
    Automobile(s): 99 Deville Concours
    Jul 2006
    Tuscaloosa, Al.
    61
    199
    Re: Oil Question?????
    When in doubt, go by what the manual says. Mine (99) says 10w30. There is no note that says to switch to something else over 100k. There IS a note that specifically says not to use any other oil than the two recommendations (10w30 and...........eerrrr I forget, the lighter stuff,.....5w20??, whatever....but that is reccomended only in very cold climates).
    Anyway, by 2 cents is to stick with the heaviest of the recomended oils. Maybe someone else has more knowledge on this than I......
    And I would get Mobile 1. I drove an Old Town car 3 miles with a snapped oil pump shaft before the lifters even started to make any noise. NO engine damage at all........it is WORTH THE $$$.
    krimson_cardnal's Avatar
    krimson_cardnal is offline Cadillac Owners Enthusiast
    Automobile(s): 96DeVille
    Aug 2005
    NY Capitol District
    69
    962
    13W40 Rotella - search it out in this forum. This is the bottom line, however.
    No need for synth. Follow the cars oil change display. AC filter. Never over-fill.
  5. #4
    69
    82,272
    119K is not high milage on a Northstar. It will run forever on conventional 10W30 . Many poster here have over 200K and a few over 300K on conventional 10W30.
  6. #5
    JohnnyO's Avatar
    JohnnyO is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado, '04 DeVille
    Nov 2003
    Pittsburgh, PA
    194
    If you use a syn or syn blend, just get the same recommended weight of 10w-30. As far as I know, Mobil discontinued the high mileage blend, at least I don't see it on the shelves anymore and I used to use it. Actually Valvoline Max Life is about 30% synthetic although it is not marketed as a blend.
  • You may not post replies
