| Re: Oil Under Intake Manifold on Northstar Yes, positive. I could see the oil just pouring over the gasket like a waterfall with the engine running. At least an inch wide. I could see it directly by looking down behind the PS pump. I cleaned the area with brake cleaner and started the motor, after about 30 seconds you can see the oil directly emerge from between the head and the gasket. No chance that it is running from anywhere else. Strange, runs like a champ.
Thanks for the pic. zonie77. I saw you had posted it somewhere earlier and after seeing the oil feed hole in that picture suspected I could see the area on the car at least at the rear head without removing anything and only the PS pump to see the same area on the front head. I ran out to look and sure enough........ The picture helped me zero in on the leak, not being familiar with the engine.
The gasket appears intact. It really looks as though the oil is squeezing out right between the gasket and the head, again at least an inch wide. You would sure think that if the head were that loose it would have blown the combustion seal.
Exactly what usally happens to the head bolts. Do they stretch, rotate out, block threads deteriorate, or does the gasket shrink from under them?
I have to say I am not pleased with the Cadillac on this issue. I know you hear all about every products perceived misgivings all over the internet in their associated forums. Every one who has problems with the products collect there, right. I have been reading alot about the NS problems too, and trying to keep it real and in perspective. I also understand failure rates and all but when you see something like this first hand it makes you wonder. And understand why so many owners are upset. There seems to be no reason this should have happened. I would wager if I could get at the area I could slide a feeler gage between the gasket and the head. It really wasn't even necessary to pass the pressurized line through the head gasket. Pity.
Any other thoughts to correct this, please post them.
Thanks again,
BTW, It also appears that there in no combustion force behind this leak. It flows out nice and steady, apparently only from the oil system pressure.
