Go Back   Cadillac Owners Group > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Northstar Stalls On Restart
Old 02-06-04, 04:45 PM
El Dobro's Avatar
El Dobro El Dobro is offline
View El Dobro's Photo Album
Casino Cash: $325
My 98 Seville stalls on restarts. Lets say that when I would pull into a gas station to fill up there's usually a 5 to 10 minute waiting period before I would start the car to leave. When I start it, it stalls right out without really catching. To keep it going, I would have to hold the gas pedal down for just a few seconds and it would idle fine after that. It doesn't matter whether it Summer or Winter and it happens after the drivetrain is totally warmed up. To top it off, it does it sporadically.There are no codes at all. I'm thinking maybe a lazy idle air control valve.
  #2 (permalink)
Old 02-06-04, 04:55 PM
elwesso's Avatar
elwesso elwesso is offline
Cadillac Owners Master
View elwesso's Photo Album
Casino Cash: $310
Re: Northstar Stalls On Restart
Im thinking maybe a leaky injector?? The pressure bleeds down on one or more cylinders and floods the engine... on more extended startups, the gas can drain down past the ring......
  #3 (permalink)
Old 02-06-04, 07:25 PM
El Dobro's Avatar
Casino Cash: $325
Nope. I already checked everything with a fuel pressure gauge. Naturally nothing happens when the dealer had the car either. That's why I'm checking to see if anyone else has experienced the same thing and came up with the solution. This way I can point the dealer in the right direction and not get the "yea, right" look.
  #4 (permalink)
Old 02-20-04, 07:36 PM
El Dobro's Avatar
Casino Cash: $325
Stalled again today when I had it filled up. Suggestions?
  #5 (permalink)
Old 02-20-04, 08:12 PM
BeelzeBob's Avatar
BeelzeBob BeelzeBob is offline
I'm a Cadillac Fanatic!
View BeelzeBob's Photo Album
Casino Cash: $250
Have you tried cleaning the throttle body bore to eliminate any deposits that may have built up that could reduce the airflow around the edge of the throttle blade and reduce the idle air control authority? That is the first thing that I would check.
Check the fuel pressure regulator by pulling the vacuum line off while the engine is idling and watch the vacuum nipple for any sign of fuel.
Does the idle speed seem OK otherwise? Any stalling at any other time? Does the idle speed elevate to a slightly higher level when the engine is cold? Does it stall on a cold start?
The other thing to do is to clean the idle air control port to make sure that the bypass air is not restricted. Cleaning the IAC valve might help and/or replacing it..... Usually if it works it works and if it is broke it stops working...no inbetween.
  #6 (permalink)
Old 02-20-04, 09:50 PM
kevinK kevinK is offline
View kevinK's Photo Album
Casino Cash: $435
Do what Bbob said, but I am not sure about the cleaning IAC valve part. According to Alldatadiy, the IAC valve can not be cleaned or adjusted.
Good luck.
  #7 (permalink)
Old 02-20-04, 11:50 PM
El Dobro's Avatar
Casino Cash: $325
The engine only stalls when it's at the normal operating temperature and has been off between approx. 5 to 10 minutes. It does not stall when started sooner or later than that period. No stumbling, no cold start stalling and has a normal cold start higher idle. There's even no guarantee that it will stall. It's that intermittant. There aren't any codes either.
It was stalling when I purchased the car from the dealer last year. At the time, I cleaned the throttle body with spray and a toothbrush. I also checked the pressure regulator for leaks. When the dealer had the car, they cleaned the throttle body, too. They also changed the pressure regulator. Personally, I don't think there was anything wrong with it, but they paid for it.
If I get a chance tomorrow, I'm going to pull the IAC valve and spray the ports. I'll check the condition of the valve, too. Maybe it's gunked up. You gotta love it!
  #8 (permalink)
Old 02-21-04, 04:31 PM
El Dobro's Avatar
Casino Cash: $325
Ok, had a chance to pull everything apart and spray the throttle body again. I removed the IAC valve and the thing was dirty, so I carefully cleaned the plunger and also sprayed the seat 'til everything was nice and shiny. I'll post my findings either way.
  #9 (permalink)
Old 02-21-04, 07:40 PM
Vesicant's Avatar
Vesicant Vesicant is online now
It takes the caek.
Cadillac(s): 0
View Vesicant's Photo Album
Casino Cash: $8115
Arrow Re: Northstar Stalls On Restart
My Catera is having a VERY simmular problem and im about ready to do that same thing as you have done, El Dobro.
Lets both hope it will/has fixed the problem!
  #10 (permalink)
Old 02-21-04, 08:17 PM
maydog's Avatar
maydog maydog is offline
View maydog's Photo Album
Casino Cash: $250
Could the EGR get stuck open without throwing any codes. I had starting problems on another car caused by a sticking EGR valve.
Tags: , ,
northstar, restart, stalls
Cadillac Automotive Concepts
bud davis cadillac
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights | air suspension kits | air suspension parts | air ride suspension
