Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Anti-Sieze and Spark Plugs
    getaway6819 is offline Cadillac Owners Member
    Automobile(s): 2005 STS
    Jun 2005
    Derby, NY
    70
    29
    I find it intresting that the subject of using Anti-sieze compound on spark plug threads was not found in a search of this forum. I also belong to the Jag-Lovers.org since I have two Jaguars a V12 XJS and a Vanden Plas. There are numerous posts there about using anti-Sieze compound on plug threads. The plugs being steel and the heads being aluminum and the corrosion problems when two metals one of which is less noble than the other are put together. I was just wondering if these problems are much less with cadillacs.
    Does any one use anti-sieze? If not then why not?
    Mike O
    Sep 2003
    Metro ATL
    4,854
    Re: Anti-Sieze and Spark Plugs
    I do not use an aftermarket thread product on new ACDelco (recommended part) sparking bolt threads because ACDelco has agreed to treat the threads of the recommended replacement part per Cadillac powertrain engineering specifications.
    Not to mention the possibility of scewing the recommended torque value reading.
    69
    82,284
    Our old Guru had always advised against it. One reason being that it will cause you to over torque them. The other being that it can cause carbon traking if not used carefully and sparingly. The plugs came out very easy on my '97 at about 90K so I did not bother using it.
  5. #4
    Jun 2005
    Derby, NY
    70
    29
    Quote Originally Posted by JimD
    Jim,
    Please explain what Ac Delco agreement and threag treatment means to me. Forgive me but I do not understand that part of your answer.
    What exactly is the correct torque value when tightening the plugs. I have seen no mention of how many FT Lbs to tighten the plugs.
    Thank You
    Mike OConnor
  6. #5
    Night Wolf's Avatar
    Night Wolf is offline Cadillac Owners 10000+ Posts
    Automobile(s): Unicycle
    Mar 2003
    Where I park it
    11,009
    well, the 4.9 has cast iron heads....
    I never heard of the dissimilar metal theory, tho I suppose its true...
    it prevents the plug from geting stuck in the block due to excess heat... I've seen that happen a few times. I use it on all of my cars and any time i do a spark plug job.
  7. #6
    Caddyshack100 is offline Cadillac Owners Connoisseur
    Automobile(s): 99STS,2004 Jeep Liberty Renegade,98 Deville RIP
    Nov 2005
    1,054
    I use anti-seize religiously on my spark plugs, I have never seen any treatments on spark plugs, even on the replacements that I changed on my 98 Deville at 100K. GM and for that matter most other OEM's use treated threads on O2 sensors.
  8. #7
    69
    82,284
    Getaway,
    I am not sure but I would venture a guess that the threads are zinc plated or something like that to prevent or reduce corrosion.
    Night Wolf,
    Dissimilar metals when in contact with each other will have an galvanic action causing corrsion. This link may explaine it better than I can.
    http://www.galvanizeit.org/showContent,173,215.cfm
  9. #8
    Feb 2004
    FL
    2,250
    Going by the "book", antiseize is not needed.
    Going by experience, antiseize is needed.
    I have never had any problem with plugs getting stuck when antiseize was used. However, in another car of mine that had aluminum heads.. I got all the plugs out but one. It welded itself in, and there was no chance of getting it out without stripping the threads or shearing it off. So I left it.
  10. #9
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    I use it on some engines I know I have seen trouble with, not on others that I have never seen problems on.
    It CAN cause problems, but it CAN eliminate problems.
    GM makes some special stuff for O2 sensors that costs about 40 bucks a can, I used to make my service manager buy one and I used it to reinstall O2 sensors and some spark plugs, mostly on aluminum heads. I don't recall it ever being an issue on cast iron heads.
    It's been a while since I had a can of that, I don't remember the part number.
    It's awesome stuff though.
    You let it dry before you install it, but don't leave the cap off the can or you'll ruin it!
  11. #10
    Nov 2005
    Point Pleasant,West Virginia
    51
    174
    From what I seen and heard it will also cause a miss fire! I know on the vette if I use them it miss fire and guys on the Forced Air Forum all have the same trouble if they use anti seize.
  12. #11
    C170B is offline Cadillac Owners Fanatic
    Automobile(s): '64 Cpe Deville, '94 Concour,2012 Prius C, 2010 RAM 1500 red
    Jan 2004
    St.Louis, MO
    163
    Non automotive comment
    Spark Plug Thread gasket compound is used frequently on piston engine aircraft engines. Many alum cyl heads have been helicoil because of thread problems. After the repair sometimes the entire helicoil will back out due to stuck sparkplug. The thread compound is supplied by the PLUG mfg so it must be important. I hear that the special ingredient is MICA in suspension. It prevents the plug from welding up and I suspect that A/C owners end up using it on their cars and lawnmowers.
  13. #12
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    If you use the wrong kind I could see it causing a misfire, also if you are not careful and you get it all over the tip of the plug... I can see that too.
  14. #13
    Patrick7997's Avatar
    Patrick7997 is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 Escalade, 07 Road King, 08 Challenger SRT8
    Oct 2005
    Pewaukee, Wisconsin
    53
    712
    I used a teeny little bit of anti-sieze on my plugs at the last change.... no ill effects. The ones on the back side of the Northstar were really stuck, so I decided to do that.....
    Correct plug torque is 15 foot pounds, I believe.
  15. #14
    parts68 is offline Cadillac Owners Fanatic
    Automobile(s): 02 Escalade,96 Aurora,with Shelby engine
    Jan 2006
    345
    small amount on the threads only
    start about 2 or 3 threads from end and
    end it before end of thread
    being sloppy is what causes misfires
    remember alittle goes a long way especially when you get it on your face.
  16. #15
    JohnnyO's Avatar
    JohnnyO is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado, '04 DeVille
    Nov 2003
    Pittsburgh, PA
    194
    I think that especially with aluminum heads you should use it. Back in the day when changing plugs was an annual thing (or more) it wasn't a big deal but with the so-called 100,000 mile plugs you can strip the threads out of the aluminum.
  • You may not post replies
