Originally Posted by feef706 I was reading my maintence manual today and at 76,000 miles I decided to take a look at the spark plugs and air filter. I pulled three plugs and one from the back all at seperate times just to see how they looked. I also pulled the air filter. I started the car afterwards and it seemed fine. Then I had to go somewhere and when I started driving down the road the check engine light came on and it started ideling rough at a stop sign. I turned around, realized i forgot to put the sensor plug back in the air filter. plugged it back in and the emissions check went away and the check engine light is now off. the car still isnt running right though. it sounds kinda strange and you can feel the engine in the car it kinda feels likes its misfiring. all the plugs are in the right order. when i push the gas it runs fine but as soon as its back to idle its rough again. anyone have any ideas what it could be. Thanks James |
Well...the first rule when you work on the engine and it acts funny afterward is to double check everything that you did...pull the plugs that you had out and make sure that the gap didn't get damaged reinstalling them, that they didn't get cracked or something R&R'ing them, that the terminals for the spark plug leads are in place in the wire boots and crimped securely, etc... Many times just pulling the wires off will damage them due to the wire pulling out of the crimped terminal, the terminal actually staying on the spark plug and pulling off the wire end, etc.....
