| Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.). | Cadillac Forums: Spark Plug Wire Placement
06-30-06, 12:45 AM
|  | Cadillac Owners Fanatic Cadillac(s): 1998 Cadillac Deville | | Join Date: Jun 2005 Location: Amherst (Buffalo), New York Age: 20
Casino Cash: $250
| | | Spark Plug Wire Placement I've seen some pictures of northstars that show the plugs being tucked around the side or a cover for them.
or this one:
this one might indicate when they switched to Coil on plug? I don't see the plug in place on the rear of the engine:
Was wondering if this was only on certain model years of from pre-production ideas etc etc
This one from the EVOQ concept car:
just curious
06-30-06, 04:38 PM
| | Cadillac Owners Connoisseur | | Join Date: Feb 2004 Location: FL
Casino Cash: $5065
| | | Re: Spark Plug Wire Placement
2000+ coil-on-plug, no plug wires.
93-94, plug wires were routed through a plastic sheath
Another 2000+
looks similar to the 4.4L northstar with the MP120 supercharger, coil-on-plug like 2000's. |
06-30-06, 04:45 PM
Casino Cash: $250
| | | Re: Spark Plug Wire Placement thanks for info, the above is the concept engine from the EVOQ, its a 4.2L northstar pumping out 400/400 I think. Its basically one of the stepping stones to what the STS-V and XLR-V's 4.4L is. My guess was "kinda" right for them all  |
07-01-06, 07:52 AM
|  | Cadillac Owners Enthusiast Cadillac(s): 1997 ETC (sold), 2004 Escalade, 2007 HD Road King Classic | | Join Date: Oct 2005 Location: Pewaukee, Wisconsin Age: 45
Casino Cash: $895
| | | Re: Spark Plug Wire Placement On a 97 Eldorado ETC, they pass under the beauty cover and go straight down to the plugs...... |
07-01-06, 09:13 AM
Casino Cash: $250
| | | Re: Spark Plug Wire Placement Quote: |
Originally Posted by Patrick7997 On a 97 Eldorado ETC, they pass under the beauty cover and go straight down to the plugs...... | yeah mine do that too, the also form the engine getting hot, leave marks from being in one spot, possibly melting alittle on there. |
07-01-06, 06:23 PM
|  | Cadillac Owners Fanatic Cadillac(s): 96DeVille | | Join Date: Aug 2005 Location: NY Capitol District Age: 61
Casino Cash: $3996
| | | Re: Spark Plug Wire Placement gotta say i like the "outside" routing of those wires. being new to the NorthStar, running ingnition under that cover just doesn't seem right, tho it does seem to work okay. most important is the correct OEM wire set... |
07-01-06, 09:04 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 40
Casino Cash: $10262
| | | Re: Spark Plug Wire Placement Not sure what the question is here really.
Maybe I am too tired.
The new ones have coil assemblies that bolt on each cam cover, no wires, just a "boot".
The original northstar had a longer wire set for the front bank and a special housing to carry the wires.
The next generation had a wire set that ran under the main engine cover with little grooves for each even wire in the top of the intake.
The newest one has coil housings with no wires.
I have had a couple 4.4s in but never paid attention to what they use. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
