Go Back   Cadillac Owners Group > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Adjust TCS Sensitivity?
Old 06-29-06, 10:35 PM
aguthmiller's Avatar
aguthmiller aguthmiller is offline
Cadillac(s): 1997 Seville STS, 1998 Seville STS, 2001 Seville SLS
View aguthmiller's Photo Album
Casino Cash: $345
Exclamation Adjust TCS Sensitivity?
Is it possible to adjust the amount of wheel slip it takes to engage the TCS during accelleration? My '97 STS (ODB II) engages the TCS very frequently during hard acceleration, especially when pulling out from a side street. It engages with much less wheel slip than my '95 (ODB I) STS did. Infact, most of the time I don't even hear the tires squeak.
  #2 (permalink)
Old 06-29-06, 11:36 PM
Ranger Ranger is offline
View Ranger's Photo Album
Casino Cash: $12796
Re: Adjust TCS Sensitivity?
Not to my knowledge.
  #3 (permalink)
Old 06-30-06, 04:38 PM
parts68 parts68 is offline
Cadillac(s): 78 Seville,96 Aurora,Caddy with Olds engine,Olds with Caddy
View parts68's Photo Album
Casino Cash: $327
you can trick the WSS to think all 4 are the same speed.
you will need to "split" the signal .
one input-4 outputs
use a rear wheel as the master sensor
  #4 (permalink)
Old 06-30-06, 09:55 PM
Casino Cash: $345
I'm not looking to disable it. I was hoping to adjust it in the PCM or TCM by adjusting one of the data values. I know with the ODB I you could adjust things like engine timing that way. Any similar method to adjust TCS?
  #5 (permalink)
Old 07-01-06, 05:45 PM
dkozloski dkozloski is online now
Cold Soaked
Cadillac(s): 2006 STS AWD, '95 Ford Ranger
View dkozloski's Photo Album
Casino Cash: $10787
It's easier to adjust your driving style.
  #6 (permalink)
Old 07-01-06, 10:28 PM
Casino Cash: $327
I m sure you could "adjust" it by making a signal on a signal generator.
The TCS/ABS uses wheel speed inputs to aid in keeping all 4 wheels at the same speed.The wheel speed sensor is a generator and the faster it goes the more voltage it puts out.Its going to be pretty hard to trick the PCM into believing all 4 wheels are traveling at the same speed.
Pull the ABS fuse if you want to burn rubber.
Tags: , ,
adjust, sensitivity, tcs
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights
