Go Back   Cadillac Owners Group > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: oil pressure loss "STOP ENGINE" warning FIX
Old 02-02-04, 11:50 AM
os101king's Avatar
os101king os101king is offline
View os101king's Photo Album
Casino Cash: $250
Thumbs up oil pressure loss "STOP ENGINE" warning FIX
if you're having an intermittent "STOP ENGINE" warning and the display is telling you that you have no oil pressure, don't rush off to the dealer. i recently posted my problem on here ('94 eldo y code) and got some seriously good help.
my problem was, as i said, and INTERMITTENT warning. it would come on after about twenty minutes of driving regardless of condition. a quick shut down and restart and the warning went away. the only time this happened that i had to drive home, after the quick re-start i shut down and let 'er cool. after that, the warning wouldn't come up until i drove the car for at least 20 minutes. i figured oil pump or relief valve at least, until one of the members of this board helped me out. bbobynksi (sp?) told me after i detailed the problem to replace the sender (oil pressure). i actually had gone to the dealer and purchased the part already, but being somewhat of a defeatist, i figured the problem couldn't be that small.
DO NOT EVER MAKE THAT MISTAKE!!! if i had gone to the dealer, odds are i would have gotten a new sender, a new valve and a new pump (maybe even a new flux capacitor) along with a fifteen thousand dollar labor bill (does ANYONE know a reputable and honest dealer service department??)
that seemed to do the trick. if anyone's in that position (remember, an INTERMITTENT WARNING!! CHECK FIRST TO SEE IF YOU HAVE OIL MOVEMENT BEFORE YOU BOTHER WITH THIS!!!) get yourself a oil pressure sending switch, the special socket (yeah, you need it), a couple jackstands and a jack. i needed to raise the motor a bit from underneath, since i couldn't get the socket to fit.
happy motoring and thanks to all that helped.
Tags: , , , , , ,
fix, loss, oil, pressure, stop engine, warning
Cadillac Automotive Concepts
bud davis cadillac
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights | air suspension kits | air suspension parts | air ride suspension
