Go Back   Cadillac Owners Group > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: How do I retrive codes
Old 02-01-04, 09:36 AM
Doug Jackson Doug Jackson is offline
Cadillac(s): 93 Allante 2004 DHS 2007 DTS Lux II
View Doug Jackson's Photo Album
Casino Cash: $250
Talking How do I retrive codes
I have a 99 STS and a 2001 ETC. I need to know how to access the computer on both of these cars. Thanks for your help. Doug J.
  #2 (permalink)
Old 02-01-04, 10:10 AM
ShadowLvr400's Avatar
ShadowLvr400 ShadowLvr400 is offline
Cadillac(s): 1996 Fleetwood
View ShadowLvr400's Photo Album
Casino Cash: $1122
Re: How do I retrive codes
You mean getting the codes? Hold down.... AC Off, and the passenger heat up button for several seconds. Leas that's what I think it is. You can also go to Autozone, they'll pull codes for free.
  #3 (permalink)
Old 02-01-04, 01:20 PM
JimD JimD is online now
Cadillac(s): '98 STS
View JimD's Photo Album
Casino Cash: $10683
Doug:
Can't help with the ETC, but your STS should be the same as my 1998 STS.
You will use the 3 buttons located to the right of the Driver Information Center (DIC) to activate and respond to the OBD prompts on the DIC.
ON/OFF = YES
INFO RESET = NO
INFO DOWN or INFO UP = manual toggle
Ignition ON, acknowledge any warning messages, press ON/OFF and INFO UP together for 2 to 3 seconds (everything in front of you lights up for 4 or 5 seconds,) then you will see:
Display shows "ALL?"
Answering YES will display "ALL CODES?"
Answering YES will run automatic test sequence and display codes, if any. Systems and codes will scroll faster than I am able to read them and write them; not to worry.
"ALL CLEAR CODES?" will display at the end of the automatic test. If you are satisfied you have the information you need, answer YES to erase all error codes.
Answerering "ALL?" with INFO DOWN will toggle systems test manually in order.
Answer "ALL?" with INFO UP will toggle system test manually in reverse order.
Press INFO RESET to restart DIC to "ALL?"
Ignition OFF to get out.
SYTEMS:
ABS (Antilock Brake System)
AMP (Amplifier)?
DDM (Door Driver Module)
DIM (Dash Integration Module)
IPC (Instrument Panel Cluster)
IPM (Instrument Panel Module)
IRC (Integrated Radio Module)
PCM (Powertrain Control Module)
RFA (Remote Function Actuation)
RIM (Rear Integration Module)
SDM (Sensing and Diagnostic Module) Inflatable Restraint?
VTD (Vehicle Theft Deterrent)
MSM (Memory Seat Module)
TTM (Tilt/Telescoping Module)
RSS (Road Sensing Suspension)
Tags: ,
codes, retrive
Cadillac Automotive Concepts
bud davis cadillac
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights | air suspension kits | air suspension parts | air ride suspension
