Results 1 to 5 of 5
Thread: Help with codes for an 02 Deville....
    86
    These are the codes I have but I don't know what they mean?
    The car died when stopping at a stop sign and the Service engine soon light came on.
    U1714 - Loss of Front Door Module to Window Motor Normal Speed Comm
    B0429 - Temperature Control #3 Rear Circuit Range/Performance
    B1004 - Keep Alive Memory (KAM)
    P0385 - Crankshaft Position (CKP) Sensor B Circuit
    Sep 2003
    Metro ATL
    4,854
    Re: Help with codes for an 02 Deville....
    P0385 is telling you why you are stalling. Replace both crankshaft position sensors would be the best plan.
    86
    Quote Originally Posted by JimD
    Thanks, do you know how much that costs at a dealership?
  5. #4
    Sep 2003
    Metro ATL
    4,854
    No idea as I do my own repairs as much as possible. Will be a warranty item if you are still covered.
  6. #5
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,854
    Thumbs up Re: Help with codes for an 02 Deville....
    Had exact same stalling/low speed problem and P0385 code set on 2002 STS with 30,000 mi. Dealer replaced both crank position sensors under warranty, problem solved. I watched the job, and sensors are not hard to replace if you can get the car high enough to work under easily. Look at other posts here and in "performance/technical" threads for online parts dealers if you're out of warranty, and for hints on replacement procedures. (A dealer will make a bundle on the recommended "flat rate" hourly cost to you.....) You're not alone.....About $50-60 apiece. Might as well change the oil and filter, too..... .
  • You may not post replies
