| Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.). | Cadillac Forums: Head Gasket Going
05-27-06, 01:22 PM
| | Cadillac Owners Enthusiast Cadillac(s): 02 Seville, 04 SRX | | Join Date: Sep 2003 Location: NY | | | Head Gasket Going I have a bit of a problem. My Eldorado has about 96k on it and is in perfect condition othr than a little problem.... one of the head gaskets is about the go and now I have a little decision to make.
I love the car to death but it seems to me that it might be getting to that age where a lot of problems are going to start comming up. I'm not sure if I should just seal it up, tell the next buyer and sell it and maybe get a Lexus or something. Or if I should just fix it. The car has already had the AC compressor replaced, a solinoid, wiring harness inside th transmission, and alternator.
As you can see a lot has already been fixed so I don't know what the hell I want to do.
For everyone that has had the headgasket replaced, how much does it usually cost? Do they need to pull the engine or can a good Cadillac mechanic do it with the engine in? |
05-27-06, 01:50 PM
|  | Super Moderator Cadillac(s): Poor man's STS--> '00 Regal GS. | | Join Date: Dec 2004 Location: Twin Cities, MN Age: 22 | | | Re: Head Gasket Going Well I'm no expert on the Northstar, but I believe the entire drivetrain has to come out to do the head gaskets. Plus, when the heads come off, you have to redrill the head bolt holes. Theres a specific name for that operation, but I forget what it's called. I think an operation like that runs you two to three thousand dollars. |
05-27-06, 05:25 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Head Gasket Going Head gaskets have been done with the engine in the car but it is more difficult than dropping the drivetrain from what I understand.
The thread insert proceedure I~LUV~Caddys8792 is talking about is Timeserts. http://www.timesert.com
$2000 would be a very good price. I seem to recall others quoting $3000 - $4000. |
05-27-06, 05:34 PM
| | Cadillac Owners Enthusiast Cadillac(s): 02 Seville, 04 SRX | | Join Date: Sep 2003 Location: NY | | | Re: Head Gasket Going So is the timeset thing cheaper or is is part of the overall process? |
05-27-06, 05:37 PM
|  | Super Moderator Cadillac(s): Poor man's STS--> '00 Regal GS. | | Join Date: Dec 2004 Location: Twin Cities, MN Age: 22 | | | Re: Head Gasket Going It's part of the overall process.
You have to redrill the bolt holes (20 of them) and timesert them. |
05-27-06, 06:23 PM
| | Cadillac Owners Enthusiast Cadillac(s): 02 Seville, 04 SRX | | Join Date: Sep 2003 Location: NY | | | Re: Head Gasket Going Time to get a new car  I guess I should start shopping. Anyone know if the 2000 + Cadillacs still have this problem? |
05-27-06, 06:47 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Head Gasket Going Any aluminum engine can have this problem, but I think they lengthened the head bolts or changed the thread pitch or something like that in 2000 to help. |
05-27-06, 07:59 PM
| | Cadillac Owners Connoisseur Cadillac(s): 94 ETC,97 STS | | Join Date: Sep 2003 Location: Arizona | | | Re: Head Gasket Going How do you know the head gaskets are about to go? |
05-28-06, 04:00 PM
| | Cadillac Owners Enthusiast Cadillac(s): 02 Seville, 04 SRX | | Join Date: Sep 2003 Location: NY | | | Re: Head Gasket Going I had my guy do the test. And we have a little white smoke coming from the exhaust.
They tried to fix this problem in the 2000 Northstar??? |
05-28-06, 10:48 PM
| | Cadillac Owners Enthusiast Cadillac(s): 02 Seville, 04 SRX | | Join Date: Sep 2003 Location: NY | | | Re: Head Gasket Going Is it cheaper to just get a lower milage engine (if I can find one cheap) and have that put in? |
05-28-06, 11:03 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Head Gasket Going If you can find a cheap one, yes but you are trading the devil you know for the devil you don't. |
05-28-06, 11:50 PM
| | Cadillac Owners Enthusiast Cadillac(s): 02 Seville, 04 SRX | | Join Date: Sep 2003 Location: NY | | | Re: Head Gasket Going Yeah, good point. About the engines though, I know its been answered somewhere in the forums but I haven't found it. What years am I limited to if I find a new engine? Its a 96 now. |
05-29-06, 01:31 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1994 Mercedes E420 / 1995 Eldorado/ 2006 Yamaha R1 LE | | Join Date: Mar 2006 Location: Clearwater Beach, Florida Age: 46 | | | Re: Head Gasket Going 96 to 99 is a direct fit. A 95 engine will also fit if you swap the intake mainifold. Also check your vin, the 8th digit is the engine code. There are two versions. A Yis a 275 hp engine and a 9 is a 300 hp engine. The final drive ratio is also different between the two. If you have a base Eldorado it will be a Y, if it's a ETC, (Eldorado Touring Coupe) it will be a 9. |
05-31-06, 06:41 PM
| | Cadillac Owners Fanatic | | | | | Re: Head Gasket Going Quote: |
Originally Posted by Yaemish Is it cheaper to just get a lower milage engine (if I can find one cheap) and have that put in? | The thread pitch on the headbolts was changed to a more coarse thread in 2000, and this was supposed to address the premature headgasket failure prevalent in prior Northstars, but according to my contact at the dealer, they still see quite a few 2000 and newer models that have headgasket issues. In April, they had a black '02 STS in with 93,000 miles where the back bank headgasket was breached causing coolant to enter the exhaust. |
05-31-06, 06:44 PM
Originally Posted by Ranger Any aluminum engine can have this problem, .............. | Maybe, but many do not. Take GM's LS1, LS6, and LS2 engines..........extremely rare to see a headgasket failure in these engines, and these are used on vehicles more likely to be pushed to the limit with spirited driving. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
