Page 1 of 4 1234 LastLast
Results 1 to 15 of 47
Thread: Switched to Mobil-1 and oil consumption dropped
    thu's Avatar
    thu is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 STS w/BoseNav, 1993 Deville, 1985 Deville
    Jul 2003
    Wyoming
    1,089
    I used to have to add one quart of oil per 1000 miles when I used dinosaur oil.
    At the last oil change, I switched to Mobil-1 synthetic and oil consumption has been cut at least by half. I drive 500-600 miles a week.
    Why is this? I thought that oil consumption would at least be the same and expected higher. The only real difference in driving conditions is that warmer weather is here. I don't know how that affects oil usage.
    I didn't change viscosity.
    I have about 2500 to 3000 miles on the current oil. It's down a quart but haven't added any yet. The oil is still golden-honey in color.
    Some of you may ask, 'why did you switch from dino to full syn?'.
    - The price of regular motor oil has climbed to an avg of about $2/qt here in Wyoming. I've noticed that a 5 quart bottle of Mobil-1 5W-30 is still $20, or $4/qt. It used to be that regular oil was $1/qt and Mobil-1 was $5/qt. Now that the price differential between the two has diminished drastically and oil changes are now between 10,000 and 12,000 miles, I'm changing oil only once or twice a year. Thus, the $15 difference per oil change 'is in the noise'.
    - I've always used Mobil-1 with spectacular results on my other Caddys. 235,000 on '85 Deville, 298,000 miles on '93 Deville - engine still going strong.
    - In the winter, the engine cranks easier, presumably putting less strain on the battery, starter, etc. Yes, it gets cold enough here (about -30*F, sometimes -40*C) in the winter to make a difference that is easily noticed.
    Anyways, just wondering why my oil consumption has dropped so much after switch to Mobil-1. Another good test will be to switch back to dino to see if the oil consumption goes back to prior levels, but that won't be for a good long while....
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,288
    Re: Switched to Mobil-1 and oil consumption dropped
    There is an unsubstantiated rumor that synthetic oil mists less in the crankcase so less is carried out the breather(PVC) system. If so this would cause a sizable drop in oil consumption.
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,920
    Very interesting. I have never used synth oil because I don't see the point. But an interesting thought none the less.
    Quote Originally Posted by dkozloski
  5. #4
    JimHare's Avatar
    JimHare is offline Cadillac Owners Connoisseur
    Automobile(s): 01 Eldo ETC, 02 Deville SOLD!
    May 2004
    Salem, NJ
    64
    1,815
    Quote Originally Posted by thu
    When did M-1 change color? Last time I saw any out of the can it was pitch black????
  6. #5
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    I use M1 in my 2000 STS and beat on it hard. I maybe have a 1/2 quart consumption per 5,000 miles.
  7. #6
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,288
    codewize, aircooled aircraft engines can be heavy breathers and one sure fire way to reduce oil consumption and clean up the belly is to switch to a synthetic oil. The low misting was related to me by a Shell oil company engineer.
  8. #7
    thu's Avatar
    Jul 2003
    Wyoming
    1,089
    Quote Originally Posted by JimHare
    When you view it on the dipstick, all oils I've used is golden-honey in color right after an oil change.
  9. #8
    thu's Avatar
    Jul 2003
    Wyoming
    1,089
    I never thought of switching to synthetics in the airplanes I fly. What I've done to three (piston-engined) airplanes was to have air-oil separators installed.
    The amount of oil dumped overboard out the engine breather can be stunning - sometimes as much as a quart per hour at high power. Yes, it winds up on the belly and cleanup is sometimes a big mess.
  10. #9
    thu's Avatar
    Jul 2003
    Wyoming
    1,089
    Quote Originally Posted by caddydaddy
    That is awesome. I just checked my Odometer and it's been almost 4000 miles since my last oil change.
    The oil level indicated on the dipstick is at the bottom of the hash portion. Does that indicate one quart or two quarts low?
  11. #10
    JimHare's Avatar
    May 2004
    Salem, NJ
    64
    1,815
    What color is it coming out of the bottle? I'm not doubting you, I just thought it was odd if Mobil changed the color of M/1 - I remember when it first came out I used it in a turbocharged Isuzu Impulse, and a turbocharged Chrysler Laser (mid 80s') and the stuff was pitch black - supposedly because of the graphite in it.
    Perhaps the formulation has changed?...just curious.
  12. #11
    69
    82,286
    I think that was so you couldn't tell what it looked like if you followed the extended service intervals they used to recommend (maybe still do for all I know). Looks just like the day you put it in 25K ago.
  13. #12
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    It's an amber color, just like all other motor oils! I never knew it was black!
  14. #13
    thu's Avatar
    Jul 2003
    Wyoming
    1,089
    I have *never* seen black motor oil when it was new. It just *looks* black because as you pour it out, you're looking through a thick portion of it. Look at it as it's just dribbling out or on the dipstick and it's amber/golden-honey.
    Mobil-1 has *always* been amber in color. I've been using it for more than ten years.
  15. #14
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,288
    Atlantic Richfield used to peddle a motor oil that contained graphite and was as black as black could get.
  16. #15
    JimHare's Avatar
    May 2004
    Salem, NJ
    64
    1,815
    Koz, you know what? I may be thinking of "Arco Graphite" - that's what you are talking about, and the synapses are starting to fail here and there in the old cocoanut - but it could be that's the stuff that I remember being black.
    I take it all back..
  • You may not post replies
