Results 1 to 11 of 11
Thread: '95 Eldorado start-up getting more "difficult"
    rrs814's Avatar
    rrs814 is offline Cadillac Owners Member
    Automobile(s): Eldorado
    May 2004
    Pacific NW
    22
    I've owned 4 caddys, and never seen this. It's almost like it has a carb! Gotta give it some gas to start, and sometimes it'll die, but then start right up afterward. Today, it was "tough", then I smelled a strong "fuel-like" smell. BEFORE I call my dealer/service rep, I'm hoping you guys can point me in some kind of direction. As always, THANKS!
    fpmesiIII's Avatar
    fpmesiIII is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Cadillac Seville STS (167k)
    May 2005
    Western NY
    473
    Re: '95 Eldorado start-up getting more "difficult"
    sounds like leaky fuel injectors
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Or a leaking fuel pressure regulator. Use the Search feature above and look for FPR. You'll find what you need to diagnose and fix it. It's an easy and relatively inexpensive fix.
    Mike
  5. #4
    Jan 2006
    1
    I had the same problem and it was the fuel regulator on the top of the engine inline with the rail that supplies the gas to the injectores. Cost about $62.00
  6. #5
    Jun 2003
    1,164
    Quote Originally Posted by Dialtone98
    Good information, Dialtone98, thanks for posting and to Cadillac Forums!
    Mike
  7. #6
    Feb 2004
    FL
    2,250
    FPR x 3,
    But if you're smelling fuel, have you had the recall work done? Don't want you bursting into flames now..
  8. #7
    Ken Seliga is offline Cadillac Owners Member
    Automobile(s): 95 customized ETC
    Mar 2004
    Cleveland,Ohio
    75
    32
    Exclamation Re: '95 Eldorado start-up getting more "difficult"
    Remember there is a recall notice from Caddy to replace the Fuel Rails the original ones were plastic/vinyl .If yours are black, then the recall has not been done..The replacement is stainless steel and there should be a sticker upon the top left strut with the recall number..Search this forum for the recall..Mine was done by Cadillac for free, just by making an appointment...The old fuel rail would split under pressure and could cause an engine "Fire"..
  9. #8
    auroradude's Avatar
    auroradude is offline Cadillac Owners Fanatic
    Automobile(s): 95 Aurora, 08 Z06
    Jun 2005
    WC, PA
    28
    244
    That sound like the recall. Your gonna blow up if you dont get that done.
  10. #9
    Nov 2005
    Point Pleasant,West Virginia
    51
    174
    On the recall, do you have to be the orginial owner? I'm the third and is there a mileage limit? The car is a 1995 STS.
  11. #10
    jadcock's Avatar
    jadcock is offline Cadillac Owners Connoisseur
    Automobile(s): White Diamond 2001 STS
    Jan 2003
    North Carolina
    38
    1,317
    You do not have to be the original owner for the recall...it's a safety recall...whomever owns the car now can have it done.
    Also, if you need a new FPR, you don't have to purchase the whole thing. GM sells a rebuild kit for about $15 (when I bought it a few years ago) and it includes all the seals and screens you need for the inside. I just needed the lower most o-ring, and was glad I didn't have to buy the whole thing.
  12. #11
    auroradude's Avatar
    Jun 2005
    WC, PA
    28
    244
    I bought the whole FPR, not a big deal. Though i havent installed it yet cause im real lazy...but the mechanic said there was gas inside it when he took it off. I hope it doesnt screw around with the motor cause theres gas in it.
  • You may not post replies
