Results 1 to 2 of 2
Thread: 93 Allante Northstar oil leak
    Jul 2005
    7
    I have a slight oil leak coming from the driver's side front where the head meets the block. There is a small machined boss on the head at the corner, and oil leaks down this boss. It dripped 3 drops in about 10 minutes, but this ads up. The engine runs great, no loss of compression from cylinders, no overheating or discoloration of the coolant. Is this common, and what is the fix? Could the oil be coming from somewhere else? Comments? thanks
    Jul 2005
    7
    Re: 93 Allante Northstar oil leak
    Can't anyone help? Thanks
  • You may not post replies
